Originally Posted by Joephu
Pan temp with a IR thermometer may vary depending on where you shoot it. This is a Flir IR image from my Lexus 2016 ES350 which is the same as the Camry/Avalon 3.5 V-6. The "red dot" on the black and white photo is where the IR thermometer was within 1-2 degrees of using a Scan Gauge 2. Either use the fill back what came out method or get a Scan Gauge/Techstream.
I Love Stuff like this! Great job.
