Don't instantly say NO, hear me out!
Hi all, I'm not exactly an amateur with home wiring. I'm knowledgeable enough to be more skilled than the saying "I know how to get myself into trouble." But getting into technicalities is above me. I'm basically just double checking my assumption.
I have a portable radiator style space heater in a detached unfinished garage/shop (completely empty) which is used to prevent my pipes from freezing (it has a toilet and sink inside it). I keep the heater almost at the bare minimum setting and it keeps it plenty warm enough.
I just bought a thermostatically controlled wall tap to use out there (it was $3, why not?), but there is no outlet in the bathroom. The water is shut off out there, so there's no chance of any water/floor/electrical issues unless the pipes burst. The entire garage including the bathroom is a concrete slab.
The problem? The closest outlet is in the main open area of the garage, approximately 2 feet from the bathroom door. The heater is in the bathroom, with the door closed and the cord draped under it (there's a decent gap, zero chance of cord damage). If I plug the tap directly into the wall outlet, it will sense the colder temperature of the main area, not the proper heated bathroom temperature.
So here's my thought process/question. I plan to use an extension cord to make this work. Basically I'm planning to do:
Wall outlet-->extension cord-->thermocube (placed in the bathroom)-->heater
I know the shorter the length of cord the better, but I also know the lower the gauge of cord the better. I have two options for extension cords. I have a 50ft 14-gauge cable, or I have a 100ft 12-gauge cable. I don't buy garbage, both are high quality and new. I'm personally leaning toward the 100ft cable because of the lower gauge. I'm sure either would be fine though.
I also plan to plug in a single 8W LED as an indicator light (which I can see from the main house) to ensure the tap is functioning properly. I trust nothing new...
So long story short, would a quality low-gauge cord with the thermocube on the end, which is hooked to a minimal setting heater be okay to use in a detached, empty, unused, uninhabited garage? What would you do differently? Which of those two cables would you use? Thanks.
