New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Helicopter
by Exhaustgases - 01/28/20 01:25 AM
Shell Helix Ultra 5W-30
by SR5 - 01/28/20 12:30 AM
Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
SandeepG, IslandOil, 01VFR, M10, H20ham
70545 Registered Users
94 registered members (2011335d, 1WildPig, 67ZL1, 53' Stude, 1978elcamino, 750IX, 11 invisible), 3,696 guests, and 24 spiders.
Topics300,667
Posts5,180,663
Members70,545
Serpentine Belt Change #5295473 12/15/19 08:59 PM
Propflux01 Offline OP
Does anyone know when the best time to change the main serpentine belt is? Mine looks good, no visible cracks or anything, with 108K miles on it. 2014 Elantra. Should I go ahead an do PM on it or let it go longer?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Serpentine Belt Change [Re: Propflux01] #5295486 12/15/19 09:07 PM
Chris142 Offline
Gates and dayco say 90k.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Serpentine Belt Change [Re: Propflux01] #5295488 12/15/19 09:08 PM
slacktide_bitog Offline
If the belt looks like it's in good shape, and there is no squeaking, you don't have to replace it yet smile
I would replace it if you ever have to replace the alternator or anything else driven by the belt, because you have to remove it anyway.
Re: Serpentine Belt Change [Re: Propflux01] #5295500 12/15/19 09:26 PM
ls1mike Offline
Trans Am is 20 years old has the original belt.
I think I changed the last trucks once when I had the water pump off. Had about 40,000 miles on it.
At 108K I would probably change it as preventative maintenance.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Serpentine Belt Change [Re: Propflux01] #5295523 12/15/19 10:36 PM
B
BigGee Offline
B
My f-150 is an 03 with 284,000 on it and the belt still looks good.Having said that ,it will break tomorrow,lol
Re: Serpentine Belt Change [Re: Propflux01] #5295537 12/15/19 11:13 PM
CharlieBauer Offline
EPDM belt wear diagnosis is from groove wear not from visual cracks:
https://www.youtube.com/watch?v=wRznjS03eoQ
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Serpentine Belt Change [Re: CharlieBauer] #5295649 12/16/19 06:29 AM
G
Gebo Offline
G
Excellent Point.
I change mine at 50K. I think most would change them at 100K, maybe????? It's easy to do.
Yes, I'd change it. As CharlieBauer said, you can't visually detect wear with this new EPDM rubber.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Serpentine Belt Change [Re: BigGee] #5295694 12/16/19 07:15 AM
Chris142 Offline
You should measure groove wear with that tool. I'm sure the grooves are worn out.
Re: Serpentine Belt Change [Re: Propflux01] #5295695 12/16/19 07:17 AM
J
Jimzz Offline
J
I replace them at the 100k service. Newer belts are made with EPDM so they don't crack like older belts. They just break when they go bad.
Good chance they can go longer but not worth it IMO.
yup
Re: Serpentine Belt Change [Re: Propflux01] #5295738 12/16/19 08:05 AM
Z
ZebRuaj Offline
Z
I do it around 100k when I do plugs and fluids. Do it all in one go.
~I fix stuff.
Re: Serpentine Belt Change [Re: Propflux01] #5295777 12/16/19 08:50 AM
supton Online Content
Online Content
I do mine at 120k but that is when Toyota says to. I'd by the manual for your car, unless if your vehicle is known for breaking belts (per any trends noted on various forums).
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 221k, his
Re: Serpentine Belt Change [Re: Propflux01] #5295935 12/16/19 12:21 PM
P
Pelican Offline
P
All belts have a mileage & time factor, rubber deteriorates even when the engine is not running, on average these days it's 100K miles or 4-5 years.
Re: Serpentine Belt Change [Re: Propflux01] #5295975 12/16/19 01:20 PM
G
Gimpy1 Offline
G
A quality serpentine belt for you vehicle is less than $30.00 and is a relatively easy change out. Why not just replace it? A tow is going to be much more especially if you have to wait 3 hours. For these simple maintenance items, just do it on your next oil/filter change it should only add 10-15 min to the "DIY service", while you're at it check your belt tensioners also.
Re: Serpentine Belt Change [Re: Propflux01] #5296094 12/16/19 03:19 PM
Prolly what I’m gonna go ahead and do.
Re: Serpentine Belt Change [Re: Propflux01] #5296155 12/16/19 04:54 PM
DGXR Offline
If all the pulleys are in alignment and the belt shows no signs of excessive/unusual wear... modern EPDM serpentine "accessory drive" belts *can* go 100k miles. They are cheap and easy to replace so I would not push it any further than 90-100k, even in the best conditions. The original belt on my Tacoma went 100k and looked/worked fine but still replaced due to miles & age. Keep the old one in the car as a spare, in case something happens.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
