Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
106 registered members (bdcardinal, 4WD, bluesubie, A_User55555, 53' Stude, Blkstanger, 9 invisible), 2,653 guests, and 23 spiders.
Topics300,432
Posts5,175,624
Members70,503
4.5" Angle Grinder #5295414 12/15/19 07:51 PM
T
TheLawnRanger Offline OP
T
This would be a good deal even if you only used it for one project. If you change the grease it would likely last a few years if you're a DIYer for occasional use.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295431 12/15/19 08:14 PM
R
Rand Offline
R
I have one of those I sharpened hundreds of mower blades with it... and a few brake pad ears. IIRC about 5amp nothing special but hey $5
Re: 4.5" Angle Grinder [Re: Rand] #5295434 12/15/19 08:19 PM
V
vw7674 Offline
V
It took 40 cutting blades........... but I dismantled & cut apart an entire VW Bus with it.
Still wants to do more.
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295442 12/15/19 08:23 PM
Z
ZebRuaj Offline
Z
These are great to have on hand for garage use. Beats having to swap disks back and forth. I have a cutting blade on one, flap disk on another, and grinding wheel on a 3rd. The 3rd one doesn't see much use.
~I fix stuff.
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295475 12/15/19 09:00 PM
M
maxdustington Offline
M
High potential for injury tool. Especially with conventional abrasive disks, might be worth the extra coin for a tool less guard, stall mitigation, etc. I personally think a paddle switch is safer but others might disagree with me. If use that grinder a lot the switch will wear out and it will shut off all the time, that's the other problem with side switch grinders.
I'd rather not skimp out on a 4.5 grinder, once you have used a high power model (10-13 amps) you won't want to go back.
99 Toyota Tercel CE 5EFE/C151
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295478 12/15/19 09:01 PM
L
Lasthope05 Offline
L
$50 minimum purchase to use the coupon.
Re: 4.5" Angle Grinder [Re: Lasthope05] #5295484 12/15/19 09:06 PM
T
T
That takes the fun out it. But, if you're spending $50 anyway, not bad. I hope this kind of coupon isn't going to be a trend.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295594 12/16/19 02:43 AM
Char Baby Online Content
Online Content
I keep thinking about this grinder(when they're coupon'd @ $9.99) but, I have the Chicago Electric version($17) just sitting around now that I've only used a hand full of times ever.
$5? That's a great price!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295595 12/16/19 02:45 AM
Online Content
OOPS, double post.
"Retired"
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295621 12/16/19 05:05 AM
F
FT92 Offline
F
have had one for years now...works well
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295666 12/16/19 06:45 AM
Donald Online Content
Online Content
I have a cheap one. The screw-on handle broke where handle was glued to bolt.
2015 Ford F-250 w/Powerstroke
Re: 4.5" Angle Grinder [Re: TheLawnRanger] #5295778 12/16/19 08:53 AM
D60 Offline
All these cheap grinders produce a lot of vibration. If you're just a hobbyist and only use it a few times per year, probably not a problem provided you don't already have hand, forearm or nerve injuries.
Once you've used a quality grinder, you'll understand the difference. Harbor Freight is also really good at spec'ing cords that flex about as well as THHN and short - anything to save a few pennies.
Companies hoping the consumer won't notice a sh***y cord is a pet-peeve of mine.
But again, for the suburban garage Bob Vila weekend warrior it'll work
