Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
110 registered members (aquariuscsm, amblerman, 87sammy, 4WD, 67ZL1, Astro_Guy, 8 invisible), 2,711 guests, and 21 spiders.
Topics300,432
Posts5,175,641
Members70,503
Alternative uses for CVT fluid? #5295315 12/15/19 05:57 PM
stroo Offline OP
I have a few quarts of CVT fluid left over from a project and I'm wondering if there are any other uses for this fluid. I use a lot of Ed's Red gun cleaner which uses trans fluid and I frequently mix trans fluid with acetone for an expedient penetrating oil. I can't seem to find much information on the web so I figured I should come to the experts. What little information I could find seemed to indicate that CVT fluid was more of a friction causing fluid for belt grip so I'm reluctant to use it like I would trans fluid.
So, does anybody have any suggestions for other uses for CVT fluid? Thinking maybe it can be used as a honing oil for my sharpening stones? Thank you and I would really appreciate any ideas!
Re: Alternative uses for CVT fluid? [Re: stroo] #5295323 12/15/19 06:03 PM
MolaKule Offline
Global Moderator
Global Moderator
Right. Use it for your Red's mixture or as a honing oil.
Or, if you have rusty tools soak those tools in it for about a week.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Alternative uses for CVT fluid? [Re: stroo] #5295337 12/15/19 06:19 PM
A
atikovi Online Content
Online Content
A
Maybe post on Craigslist?
Re: Alternative uses for CVT fluid? [Re: stroo] #5295343 12/15/19 06:31 PM
A
austinlunsford Offline
A
If you have an old diesel, I’d dump it in the fuel tank
1997 F250 HD 7.3: Delvac 5W-40
2002 F150: M1 HM 0W-20
2003 Taurus: M1 EPHM 5W-20
2016 Renegade: Valvoline Modern Engine 0W-20
Re: Alternative uses for CVT fluid? [Re: stroo] #5299189 12/19/19 03:57 PM
stroo Offline OP
I've soaked some rusty parts for about ten days in this CVT fluid, taking them out every few days and hitting them with a wire brush. The results have been disappointing, definitely doesn't work as well as regular ATF for soaking into metal and softening corrosion. I was hoping for some more info on this stuff and what else it might be good for. Guess I'll give the last few quarts to a local trans shop. Thanks guys!
