Grease for Blend Door Actuator
by TheLawnRanger - 01/25/20 01:05 PM
waterpump fan clutch and thermostat now overheating
by HyundaiAbuser - 01/25/20 12:43 PM
2020 Ford F250 w/Tremor package and 7.3 L
by tenderloin - 01/25/20 12:34 PM
Genesis GV80 SUV
by tenderloin - 01/25/20 12:33 PM
What kind of mixed drink do you like?
by 53' Stude - 01/25/20 12:11 PM
F150s with the 6.2L
by ford46guy - 01/25/20 12:09 PM
Generator - Gas or Not
by coopns - 01/25/20 11:18 AM
Oil Recommendations For Leaks?
by shurguywutt - 01/25/20 10:59 AM
'12 Odyssey EX-L trans filter
by shortlid - 01/25/20 10:57 AM
06 Explorer v8
by ford46guy - 01/25/20 10:31 AM
Heard this today 🤣
by JLTD - 01/25/20 10:18 AM
Has anyone tinted a dash cluster?
by Vern_in_IL - 01/25/20 08:40 AM
Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
M635_Guy, ame299, Whoop, coondog, steelbeams
70523 Registered Users
93 registered members (2010Civic, 97prizm, 2003f7, 53' Stude, 55hambone, 11 invisible), 3,404 guests, and 22 spiders.
Topics300,539
Posts5,177,969
Members70,523
Bleed and refill? #5295251 12/15/19 04:19 PM
cwilliamsws6 Offline OP
My mom had me check the fluid levels in her car today (04 Element, 124.xxx miles) and the brake fluid reservoir was BONE dry. Took half a bottle to fill it to an acceptable level.
Pretty safe to say there's air in the system and I should get the brakes bled right? Just wanting someone to confirm or deny my suspicion. TIA
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: Bleed and refill? [Re: cwilliamsws6] #5295254 12/15/19 04:25 PM
9
97prizm Online Happy
Online Happy
9
I would definitely +. I saw this once as an emissions Inspector with a lady in a jaguar. Not sure how your mom could stop.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Bleed and refill? [Re: cwilliamsws6] #5295257 12/15/19 04:28 PM
W
WhyMe Online Content
Online Content
W
if its that dry you need to check the reason why. either the all the brakes are worn or you have a leak somewhere.
Re: Bleed and refill? [Re: cwilliamsws6] #5295263 12/15/19 04:44 PM
I dunno how she was able to stop either. I don't know if I should be terrified or impressed by this... gonna have my buddy look over all the brake lines for me in a bit and help me bleed and refill at least for the time being.
Re: Bleed and refill? [Re: WhyMe] #5295265 12/15/19 04:51 PM
Chris142 Offline
Even if all the pads are worn out it should still have fluid in the reservoir. If there's nothing in it you have a leak that needs to be fixed now.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Bleed and refill? [Re: cwilliamsws6] #5295266 12/15/19 04:52 PM
I
Imp4 Online Content
Online Content
I
You should be both terrified and impressed.
More importantly, you should get it checked pronto...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Bleed and refill? [Re: cwilliamsws6] #5295299 12/15/19 05:39 PM
A
atikovi Online Content
Online Content
A
She didn't see the low fluid light on? Did you drive it afterwards to see how it feels? Theoretically the fluid could have been right at the bottom of the reservoir so no air got in, but has the fluid ever been changed?
Re: Bleed and refill? [Re: cwilliamsws6] #5295313 12/15/19 05:53 PM
X
xtell Offline
X
My as well go ahead and bleed the breaks. That way new fluid will be in all the lines and once properly filled without any potential air in the lines, you will be able to truly see if there is a leak somewhere in the lines (in the case the fluid does continue to go down).
Re: Bleed and refill? [Re: cwilliamsws6] #5295318 12/15/19 06:01 PM
Donald Online Content
Online Content
OP- did you try the brakes after filling the reservoir? Engine running. The car should be towed to a place to bleed the brakes and find the leak. I would guess a rusted brake line in a 15 yr old car in Ohio. I assume salt and rust in Ohio.
And it's likely that some bleeder screws are seized. That can mean from some extra work to a new caliper.
2015 Ford F-250 w/Powerstroke
Re: Bleed and refill? [Re: cwilliamsws6] #5295319 12/15/19 06:02 PM
There was no low fluid light, and I was driving her car earlier today and the breaks worked and felt totally normal... felt the same after topping the fluid off too. Confused as [censored] about the whole thing.
Fluid was changed once like 5 years ago and just topped off as needed. Obviously we've been slacking on that last bit.. lol
Re: Bleed and refill? [Re: cwilliamsws6] #5295321 12/15/19 06:03 PM
A
Online Content
A
If it feels good, I wouldn't worry about it. Maybe it wasn't bone dry? Is the reservoir pretty dirty? How did you tell it was empty? How is the emergency brake?
Re: Bleed and refill? [Re: cwilliamsws6] #5295327 12/15/19 06:09 PM
Reservoir pretty clean, knew it was bone dry because I put my finger in it, touched the sides, and even down in the bottom and it was d r y. Nothing in there at all.
E brake works fine, tested it on our absurdly steep driveway.
Re: Bleed and refill? [Re: cwilliamsws6] #5295334 12/15/19 06:17 PM
A
Online Content
A
Well, as long as it feels strong and the E brake works fine I'd drive it but but check the level often in case there is a leak and the fluid should be changed if it never has been before. And maybe see why the warning light doesn't work. Isn't that part of a safety inspection?
Re: Bleed and refill? [Re: cwilliamsws6] #5295418 12/15/19 07:56 PM
H
hallstevenson Online Content
Online Content
H
There was no low fluid light...
Does the fluid reservoir cap have a single electrical wire going into the top of it ?
Re: Bleed and refill? [Re: cwilliamsws6] #5295441 12/15/19 08:23 PM
E
Eddie Offline
E
Just because there was no fluid in the reservoir doesn't mean the master cylinder was empty. I suspect the pads are down to minimum or below. Ed
2014 CX5 Touring 2.5L :-)
