2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
59 registered members (94astro, alarmguy, 97K15004WD, bachman, Bailes1992, Best F100, 4 invisible), 1,449 guests, and 29 spiders.
Topics301,899
Posts5,204,910
Members70,798
Porter Cable 12V Batteries #5294560 12/14/19 06:52 PM
B
bcossa2001 Offline OP
B
The 2 factory batteries for my 12V Porter cable cordless drill are dying.
Looks like there are a number of replacements on Amazon by companies with which I am not familiar: Shentec; Joiry; Poweraxis; Reexbon; Powergiant. These are all less than 50% of the cost of the Porter Cable brand ($58)...
Does anyone have good/bad experience with 12V replacement batteries for cordless tools??
Thanks in advance...
"Facts are pesky things"
2003 Town & Country--143 k
2016 Fusion 8 k
2016 Fusion 34 k
2017 Santa Fe 8k
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294586 12/14/19 07:28 PM
B
BISCUT Offline
B
I was in the same situation with a decade old DeWalt set of tools. I went crazy over it but in the end I sold the old and got a new DeWalt set. man what a good decision that was. I bought the 2.5 amp batteries and waited to save for a 5amp. It was the right decision for me. from what I've gotten out of the secondary battery market (tools and camera batteries) they are a ok for a while but last no where NEAR what the OEM batteries last. And by the time you know it it's too late to return. Food for thought.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(44k)
2017 Sub OB M1 5-30 EP FRAM Ultra(74k)
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294598 12/14/19 07:39 PM
Californiabob Offline
my experience was different. I have this Black&Decker weed whacker that uses 18V slip-on batteries.
since I use them seasonally, the OEM batteries would fail after one season. and just past the warranty.
then I tried replacing the batteries using Harbor Freight cheapy batteries and swapped the battery packs.
these lasted longer but weren't strong enough. all up to date were NiCads, about 1200 or 1500 mah
then I bought some NiMH off eBay at about 3500 Mah - these did the job: runs long, in use 3 years
and still going strong.
I suspect power tools need LiOn batteries for the draw and capacity.
I'd try a cheapy high Mah battery but make sure they're compatible with your charger
(match the battery's tabs to the charger pins and make sure the charger likes the battery type).
CaliforniaBob
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294649 12/14/19 08:34 PM
tom slick Offline
I’ve had mixed results with aftermarket batteries for my Milwaukee tools. The replacements for my old NiMh tools were upgrades and seems better than the originals. The replacements for my LiOn tools have been mediocre.
It’s worth is gamble if you like the tools.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294752 12/14/19 11:27 PM
spackard Offline
On EBay, I've bought two 15.6V NiCd packs that were "Tank" brand, from a seller named backupdog.
They've worked out okay.
There are also battery rebuilders there, but if the pack is difficult to dismantle they'll have problems with it.
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294760 12/14/19 11:49 PM
W
WhyMe Offline
W
toss them and get a ridgid set and never worry about batteries again. i have had 2 set of batteries sent to me for free from ridgid for my close to 10 yo 18 volt set
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294768 12/15/19 12:25 AM
Dave9 Offline
Most of the reviews with testing of these generic 3rd party packs, suggests that the packs (cells) are typically over-rated by quite a bit and often cannot supply as much current, so you may essentially be getting 1/2 to 2/3 the battery you think you are.
Whether that is a good value if you're only paying half as much, "depends" on the use. For a cordless drill with only 12V to work with, I'd lean towards no, it's not worth it to get a generic unless you're demoting the drill to (lighter) screwdriver duty.
