Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
dfrybeck, ckinch1, EAC1, Kronguy, jamespeter26
70492 Registered Users
93 registered members (90crvtec, Anthony, 77GrandPrix, A310, 28oz, amblerman, 9 invisible), 2,439 guests, and 22 spiders.
Topics300,381
Posts5,174,667
Members70,492
Porter Cable 12V Batteries #5294560 12/14/19 06:52 PM
B
bcossa2001 Offline OP
B
The 2 factory batteries for my 12V Porter cable cordless drill are dying.
Looks like there are a number of replacements on Amazon by companies with which I am not familiar: Shentec; Joiry; Poweraxis; Reexbon; Powergiant. These are all less than 50% of the cost of the Porter Cable brand ($58)...
Does anyone have good/bad experience with 12V replacement batteries for cordless tools??
Thanks in advance...
"Facts are pesky things"
2003 Town & Country--143 k
2016 Fusion 8 k
2016 Fusion 34 k
2017 Santa Fe 8k
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294586 12/14/19 07:28 PM
B
BISCUT Offline
B
I was in the same situation with a decade old DeWalt set of tools. I went crazy over it but in the end I sold the old and got a new DeWalt set. man what a good decision that was. I bought the 2.5 amp batteries and waited to save for a 5amp. It was the right decision for me. from what I've gotten out of the secondary battery market (tools and camera batteries) they are a ok for a while but last no where NEAR what the OEM batteries last. And by the time you know it it's too late to return. Food for thought.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(40k)
2017 Sub OB M1 5-30 EP FRAM Ultra(70k)
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294598 12/14/19 07:39 PM
Californiabob Offline
my experience was different. I have this Black&Decker weed whacker that uses 18V slip-on batteries.
since I use them seasonally, the OEM batteries would fail after one season. and just past the warranty.
then I tried replacing the batteries using Harbor Freight cheapy batteries and swapped the battery packs.
these lasted longer but weren't strong enough. all up to date were NiCads, about 1200 or 1500 mah
then I bought some NiMH off eBay at about 3500 Mah - these did the job: runs long, in use 3 years
and still going strong.
I suspect power tools need LiOn batteries for the draw and capacity.
I'd try a cheapy high Mah battery but make sure they're compatible with your charger
(match the battery's tabs to the charger pins and make sure the charger likes the battery type).
CaliforniaBob
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294649 12/14/19 08:34 PM
tom slick Offline
I’ve had mixed results with aftermarket batteries for my Milwaukee tools. The replacements for my old NiMh tools were upgrades and seems better than the originals. The replacements for my LiOn tools have been mediocre.
It’s worth is gamble if you like the tools.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294752 12/14/19 11:27 PM
spackard Offline
On EBay, I've bought two 15.6V NiCd packs that were "Tank" brand, from a seller named backupdog.
They've worked out okay.
There are also battery rebuilders there, but if the pack is difficult to dismantle they'll have problems with it.
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294760 12/14/19 11:49 PM
W
WhyMe Offline
W
toss them and get a ridgid set and never worry about batteries again. i have had 2 set of batteries sent to me for free from ridgid for my close to 10 yo 18 volt set
Re: Porter Cable 12V Batteries [Re: bcossa2001] #5294768 12/15/19 12:25 AM
Dave9 Offline
Most of the reviews with testing of these generic 3rd party packs, suggests that the packs (cells) are typically over-rated by quite a bit and often cannot supply as much current, so you may essentially be getting 1/2 to 2/3 the battery you think you are.
Whether that is a good value if you're only paying half as much, "depends" on the use. For a cordless drill with only 12V to work with, I'd lean towards no, it's not worth it to get a generic unless you're demoting the drill to (lighter) screwdriver duty.
