Are you going to clean carbon off pistons? How does the valves look? Might as well clean carbon on those also. At least we can see Mobil 1 effectiveness.
Here is my synopsis of the ls plant mike. My buddies and I all started motorheading small block bow ties in the mid late 70's if you were lucky enough to find a set of double humpers it was a (.........) good day! If you were THE one to find a set of angle plug heads YOU were king (........) ! Hopefully you could sell enough (.....) to come up with the cash before they were gone.
Now my buddies and I run dual planes and either TBI or carbs on these and you can look into the throat of a dual plane with stock cathedral heads and a good portion of the top of the valve surface is visable..
these are unbelievable platforms and there were millions of them made. It's going to be a long long run before these are exhausted!
No.
I need to give the Ford and Import guys a chance.
In reality it isn't hurting anything and they will look like that in a few thousand miles anyway.
