Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
P38 Lightning
by Kamele0N - 01/16/20 03:01 PM
Why does oil in the spark plug hole cause misfires?
by berniedd - 01/16/20 02:27 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
75 registered members (2015_PSD, adams355, alchargo, alarmguy, 4WD, 53' Stude, 5 invisible), 1,364 guests, and 15 spiders.
Topics300,215
Posts5,171,076
Members70,452
Most Online3,728
Jan 11th, 2020
Subaru Forester with rusty brakes #5294293 12/14/19 12:55 PM
Donald Offline OP
I get the "brake pad is gone" scraping noise when turning left and no brake applied. Previous post of mine said it was turning right. Brakes are fine. I believe the rotors are Wagner coated rotors.
Besides the NY taxes the NY rust is out of control. This car does get sprayed with rust treatment.
Moving in spring to what I hope is below the rust line (Delaware).
2015 Ford F-250 w/Powerstroke
Re: Subaru Forester with rusty brakes [Re: Donald] #5294448 12/14/19 04:02 PM
G
GZRider Offline
G
Calipers are sliding pin type and sticking a bit, probably time for rebuilt ones.
Re: Subaru Forester with rusty brakes [Re: GZRider] #5294559 12/14/19 06:52 PM
Donald Offline OP
The brakes do not make any noise when I use them. Just makes a sound like brakes do when turning left.
Re: Subaru Forester with rusty brakes [Re: Donald] #5294569 12/14/19 07:06 PM
slacktide_bitog Offline
Maybe the dust shield got bent somehow
Re: Subaru Forester with rusty brakes [Re: Donald] #5294628 12/14/19 08:11 PM
B
BISCUT Offline
B
That's odd in my book. My rotors get rusty but I've never gotten what your stating. I'm running a 17 Outback. My OEM brakes lasted 60k. A record BY A LOT for me. Too much salt exposure for me.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(40k)
2017 Sub OB M1 5-30 EP FRAM Ultra(70k)
Re: Subaru Forester with rusty brakes [Re: Donald] #5294736 12/14/19 10:33 PM
H
HangFire Offline
H
Could be a bad wheel bearing.
Delaware is hardly below the rust line, but being a warmer state with most of its land mass on the coast near the Gulf Stream, tends to have a LOT less snow than NY. Hurricanes can be an issue, though.
Various musings: http://hangfire.net
Re: Subaru Forester with rusty brakes [Re: Donald] #5294926 12/15/19 08:43 AM
supton Online Content
Online Content
Pretty much stuck looking to see what is up. IMO you need to bust apart brakes once a year up here, so much road salt. Although I think constant exposure to water will wash away brake lube (and under carriage oiling too).
Of course it could be something else. For a while my truck would make a rattling sound, like heat shield, but only on certain turns. But never any other time. ??? In the end, I got up under it, found that the shield was loose, put a band around it, and no more rattle on turns. Maybe you have similar.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
