2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
94 registered members (ArrestMeRedZ, AlienBug, aircooled, 4WD, Alfred_B, aquariuscsm, 7 invisible), 2,596 guests, and 20 spiders.
Topics300,313
Posts5,173,054
Members70,471
Most Online3,728
Jan 11th, 2020
Extend OCI with STP? #5293338 12/13/19 10:28 AM
cwilliamsws6 Offline OP
As mentioned in previous threads I recently changed my oil and this time used 15oz blue bottle STP.
My car's OLM seems to kick on the "change oil" light around 5,000 miles but I was wondering if it's possible to extend out this OCI because of the additives from the STP I imagine it'll last a bit longer?
Just curious. Thanks
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293345 12/13/19 10:36 AM
csandste Offline
STP came in handy for me when the ten weight winter oil was in my '53 Mercury (in the mid sixties) and it got warm in the spring. You raised the weight of your oil during the winter--in Ohio, not much else. Don't think it would do a thing to extend your OCI.
2017 Kia Soul Plus-- VWB 5w30+ a bit of Harvest King syn 5w30-- 70,000 miles
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293352 12/13/19 10:42 AM
JohnnyJohnson Offline
A UOA can help you with this decision.
2004 Corolla 138348
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293361 12/13/19 10:50 AM
G
gfh77665 Offline
G
I have wondered the same thing. If additives are boosted a bit, I think the OC can be extended. Of course someone will point out that STP does not make oil new again, or remove contaminates, but thats not the point. I think a good additive would buy you some time. It should mitigate some depletion of the oils additive package.
Re: Extend OCI with STP? [Re: JohnnyJohnson] #5293395 12/13/19 11:16 AM
O
OVERKILL Online Content
Online Content
O
A UOA likely costs more than just changing the oil in this case.
OP: STP isn't turning your conventional vanilla sauce into M1 EP or AMSOIL.
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293408 12/13/19 11:30 AM
Donald Offline
STP will most likely reduce the OCI you should run.
People used STP to thicken oil to pass emissions tests 20 or 30 years ago.
Use high quality oil and forget additives.
STP = Studebaker Testing Products
2015 Ford F-250 w/Powerstroke
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293411 12/13/19 11:32 AM
RDY4WAR Offline
STP is just a thick bottle of OCP VII with a weak (and diluted) add pack in a group I carrier. It's pretty much the same as Lucas Oil Stabilizer except Lucas contains no add pack at all. It WILL shorten the OCI as the anti-oxidants, detergents, dispersants, and anti-wear additives in your oil will be diluted by it.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293431 12/13/19 11:49 AM
supton Offline
Is your OLM nothing more than an idiot light? The two in my Toyota's are programmed to come on just prior to the 5k mark. That is because they "need" tire rotations every 5k, with oil changes every other. Completely miles based. [Which works fine by me, for the record.]
I tend to have low opinions of additives. If they did something, they'd be in the oil already. Maybe they are, but in the high dollar oils. Who knows. As a last ditch effort to keep a poorly running engine going, ok no harm no foul. Maybe in really big engines with gallons of oil, maybe an additive makes sense... but that wouldn't apply to a passenger car with what, 4 or 5 quarts of oil?
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293629 12/13/19 04:01 PM
Clayslayer Offline
Meh. STP might help? It can't really hurt I suppose. A good modern day synthetic (Mobil 1, Amsoil, etc) will last. Many are guaranteeing a one year OCI or up to 25,000 miles with use in certain applications. I'm not a huge fan of additives. I figure the engineers at the companies know a wee bit more than I do. FWIW I do Amsoil signature once a year in all of my stuff regardless of mileage.
Re: Extend OCI with STP? [Re: cwilliamsws6] #5293718 12/13/19 06:03 PM
blupupher Offline
All the blue bottle does is add some ZDDP (which could be argued that you do not need for that vehicle) and thickens the oil, it does nothing to extend the change interval.
It really does nothing to help, and as said above, it may hurt by diluting the actual additives in the oil.
I would change it now and then just use oil in the future.
If you want to extend the interval, use a quality synthetic, not HK conventional (which there is nothing wrong with for a standard OCI) and STP.
Depending on your driving conditions, HK synthetic would probably be fine for a 7500 mile interval (but a UOA will be the only way to know for sure).
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Extend OCI with STP? [Re: blupupher] #5293734 12/13/19 06:23 PM
RDY4WAR Offline
The amount of ZDDP in STP is <600 ppm Zn and <500 ppm P so it actually dilutes the ZDDP concentration in your oil.
It's another example of deceptive marketing where they say "contains anti-wear additive ZDDP" but careful not to say how much.
