Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
bbrtuning, chapys, DaaBoss, C6H8O7, Jcvjr
71591 Registered Users
79 registered members (2015_PSD, 14Accent, 4WD, 28oz, 53' Stude, 10WSmuckers, 9 invisible), 2,488 guests, and 28 spiders.
Topics306,031
Posts5,286,096
Members71,591
Page 1 of 3 1 2 3
Trying to decide on an oil for new Subaru Forester #5293007 12/13/19 12:14 AM
Q
qball16 Offline OP
Q
Hi.
I've been doing a fairly obsessive amount of research on what I want to run on our 2019 Forester. First oil change is coming up. I've never owned a car with so many oil mysteries that can't seem to be agreed upon. There is the oil filter bypass PSI issue and the new DI and possible fuel dilution and fouled intake valve concerns. There are also reports of square filter gaskets leaking. I finally jumped the first hurdle and just ordered 4 OEM Subaru filters and crush washers. My second choice would have been the WIX 7055, but it has a square gasket. The high end option would be the Tokyo Roki filter made for the Mazda RX-8. This would be a very similar filter to the one that comes on the car from Japan. These are a good deal more expensive and I liked getting the washers in the package.
So now I need to settle on an oil. My main concerns are fuel dilution and whether the oil contributes to intake valve fouling due to recirculated crankcase gasses containing oil. There is a great deal of conjecture as to whether low NOACK is vital for the valve issues. Some say that it reduces vaporized oil in the intake gasses. Others say that the offending oil is actually a mist, not a vapor, and that low NOACK isn't a magic bullet. Then we get to calcium numbers and calcium vs magnesium and sulfated ash numbers. What do you think about PAO vs GTL for fuel dilution?
If I wasn't obsessing I'd run down to WM tomorrow and grab a jug of Mobil 1 Extended Performance in 0w-20. I still just might do that. Does anyone have any personal insight or preference in this specific situation? I also think I'll order a Fumoto for this one. Because the filter is right on top, I wouldn't have to use ramps at all.
Anyway, what oil should I use?
2012 Honda Pilot EX AWD - M1 0w-20 EP HM/Fram Ultra
2019 Subaru Forester Limited - Pennzoil Platinum 0w-20/Subaru OEM blue filter
1978 Honda HR-21 Lawn Mower - Amsoil small engine 10w-30
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293025 12/13/19 12:57 AM
J
john_pifer Offline
J
Are you going to run it hard at all? If not, I’d say your thought of M1-EP 0W-20 would be a fine choice. I’ve read here that it has a nice dose (up to 60%, even?) of PAO (fully synthetic group IV fluid). Noack value should be acceptable (probably 10-11%) for a 0W-20. Modern formulation will have lower Ca to fight LSPI, and higher Mg (detergents). It will have some moly and some boron as anti-wear/friction reduction. And it’s available at any local store.
Just do some research on here and compare VOAs and UOAs of various oils. And see which one you like.
There should also be some Forester UOAs to look at.
I can tell you that I ran PPPP 10W-30 in my 2016 WRX for the 3 years I owned it and i had zero issues. I chose it specifically because it had some of the lowest Noack values of any oil at ANY price. And the WRX calls for a 5W-30. And I ran it hard at times, to put it mildly.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 228K
18 Civic HB 1.5T 6MT (Wife's) - PPPP 10W-30, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293061 12/13/19 03:17 AM
dave1251 Offline
If the concern is fuel dillution PAO baseoil's are not the best choice although I believe you are looking to far into the pine needles here. For fuel dillution the better option is something with a ester such as Castrol Magatec or a HM oil with an ester.
don't use.
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293085 12/13/19 05:00 AM
Danno Offline
If it was my Subaru, I would use a known high quality oil such as PP, in the viscosity recommended by Subaru, change it on severe schedule, and and sleep well.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293094 12/13/19 05:22 AM
T
Triple_Se7en Offline
T
Need more info
City - highway driving ratio?
How much daily idling in cold Wisconsin?
How long will your OCIs be?
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293099 12/13/19 05:51 AM
sopususer Offline
Any quality brand name 0W-20 syn is going to be fine. As far as filters are concerned, the OEM Subaru will of course be fine, but with three Subarus in my current fleet, I can attest that I have never had a Wix/Fram filter leak at the gasket. The 57055/7055 is a good choice as well in the future.
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293110 12/13/19 06:22 AM
STIcandy Offline
I'm running Motul ecolite 0w-20/ OEM filter combo in a 2019 subaru crosstrek with (seemingly) good results. This is my cousins car that I maintain and she already has 50,000kms on it. She does basically 10k kms every two months. Doesn't burn a drop or smell like fuel whatsoever. Unfortunately I can't back that up with stats yet as I haven't done a UOA but am doing so in the near future in an effort to extend the OCI out a little more.
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293117 12/13/19 06:32 AM
Donald Offline
I use NAPA synthetic 0W20 oil in both my Subarus and buy it on sale. I buy OEM Subaru filters by the 6 pack on Amazon for a good price. Not that I am one to say only use OEM filters. I got a quantity of NAPA Platinum filters on a very good sale for my Subaru and Ford F250 so I am using those now.
I have the feeling that people who buy a Subaru Forester are not going to be driving them hard.
The Subaru (both of mine) does require a synthetic 0W20 oil.
Fumoto valve makes oil changes a snap.
2015 Ford F-250 w/Powerstroke
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293138 12/13/19 07:05 AM
G
Gebo Offline
G
If it were me, I'd run the OEM Subaru Filters from dealer, OCI 3K, and run a Pennzoil product in the weight recommended.
But there is nothing wrong with Mobil. What does the dealership use? Subaru forums? You need to have confidence in
your oil of choice and there isn't gonna be a consensus here (I don't think). What does your gut tell you? Mobil?
Please don't fall for this extreme extended drain interval. I'd never go more than a 5k OCI on anything. You spent a lot of money
for your new Subaru and I would treat it with the utmost care. I'll be called wasteful, ignorant, goofy, etc but if I could do
over I would have done 3K OCI's on all my cars with OEM from the dealer filters. Too many copy cats selling filters that look
OEM.
I Fumoto'd 4 of my cars and was very disappointed in "my" applications. I removed them all as they stuck down and I was afraid I'd hit something
and break them off and lose all my oil.
They left more oil in the drain pan than when I used the drain plugs. Notice I referred them as "MY" applications. Your application may be much better and safer.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293141 12/13/19 07:12 AM
K
ka9mnx Offline
K
SN+/D1G2 should work fine.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293148 12/13/19 07:26 AM
PimTac Offline
Any major brand of oil that meets the specs for your Forester will run just fine. As mentioned already, SN+ and d1G2 are the better options especially if this is a GDI engine.
As for the Fumoto, that’s a personal decision. How much room do you need to get under the vehicle? A safe and inexpensive way is to use some scrap 2x lumber and make your own stacked ramp. 2x8 will work. I use this on my CX5.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Trying to decide on an oil for new Subaru Forester [Re: Triple_Se7en] #5293254 12/13/19 10:01 AM
Q
qball16 Offline OP
Q
Thanks for all the replies. I left out some important info. The car is usually driven by my wife - just 5 miles in the morning, then probably 10 more with errands later in the day. And it gets remote started 4 or 5 times a week for 5 minutes on the cold WI mornings. I know, not ideal. I have not experienced obvious fuel dilution in the first 4.5k miles.
My planned OCI will be no more than 5000 miles to start. The car won't be driven hard but when I get to drive it on weekends, I try to get the revs up and the oil temp up to 225 for a while, I drive it in S mode for higher revs and fortunately they gave drivers an option to put an oil temp readout on the upper display.
I'm hoping that I can can get at the Fumoto without ramps. I own ramps, just would be nice to not have to drag them out. If I can't get at the plug without ramps, I don't think the valve will really make much of a difference. Donald, can you get at the valve without lifting the car? I don't think I'll analyze the first change, but will send in a sample of the first OCI from my chosen oil.
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293266 12/13/19 10:10 AM
A
ARCOgraphite Offline
A
Originally Posted by qball16
Hi.
Yep you got it bad. But Ive done the research and have owned 3 FB20/25 engines already.
Best is Valvoline Advanced 0W20 with a 1/2 qt of Magnatec 5W20 on top.
Superb - maybe the best - UOA on a Subaru .Crossrek FB2) and We went 9k miles.
https://www.bobistheoilguy.com/foru...mi-17-subaru-crosstrek-52665#Post5205570
More Advice:
Don't overfill by any amount.
I would order and use the Roki filters if possible.
The Fram/Subaru blues are just OK.. but have TC noise issues.
The Filter is up top near the battery tray with a spill-over basin,so you can monitor leaks if you go WIX.
NO Fumoto! Just hearing that name makes me want to grab an M1 Carbine.
There should be a window in the undertray to get to the oil drain plug. If Not - Cut one.
No M1 in Subaru - they don't like it historically. But if you do, Use the EP and leave it in for 10K if you drive over 20K a year.
Good luck. Now worry about the CVT trans instead smile smile smile
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Trying to decide on an oil for new Subaru Forester [Re: qball16] #5293268 12/13/19 10:14 AM
Doublehaul Offline
I had a forester and a outback with the fb25 engine. I ran 15k ocis on Mobil 1 EP. great UOAs...keep an eye on your oil level. Those engines have a bad ring design and are known to burn it...
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Trying to decide on an oil for new Subaru Forester [Re: ARCOgraphite] #5293271 12/13/19 10:16 AM
Doublehaul Offline
Hi.
More Advice:
Yes both of mine shelled the cvt at around 90k. Some ridiculous price like 6500$ was quoted so o traded em in. I thought the first was a fluke so I got another subie...the second was traded in another brand
Mobil 1 0w40
Page 1 of 3 1 2 3
