Thanks for posting. IDParts is also a potential source for the fluid and filter kits. I've probably done 10 or more DSG changes and have a recommendation if you're in for long term VW ownership. Buy a new drain plug then drill and tap with a hose barb (~$15) plus get a marine lower unit fluid pump ($10). You'll save at least an hour pumping fluid in from the bottom. VCDS here also. Good luck, John
