Originally Posted by mpgo4th
Sorry but I'm still a little confused. So this means it "can" possibly stop particles 9.8 microns but it "will" stop 27 micron particles?
It means it filters out 50% of all particles that are as small as 9.8 microns, and filters out 98.7% of all particles as small as 27 microns.
Would this equate to a higher flowing filter than a 20 micron at 98.7% filter?
Filter flow performance (flow volume vs delta-p across the filter) is not always connected to the efficiency.
In other words, the falsehood that never seems to die - that being "more efficient oil filters are more flow restrictive" - isn't necessarily true, especially with full synthetic media.
Besides, the flow vs delta-p performance difference between good mainstream filters isn't big (especially with hot oil), and any good positive displacement oil pump isn't going to suffer, and will still supply the same oil flow volume in most cases.
