Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
117 registered members (2011335d, 928, 1978elcamino, 11 invisible), 3,933 guests, and 25 spiders.
Topics300,353
Posts5,173,994
Members70,491
Will moving steering via wheel hubs cause harm? #5292004 12/12/19 12:26 AM
M
mobilaltima Offline OP
M
Changed the pads rotors and calipers front and back on my work truck that I just bought recently, 2012 F150 2wd with 154k. One of my friends helped me to make the process go faster. He was doing the driver side front, and had the rotor, caliper and pads on. The whole assembly was turned to the passenger side, so he grabbed it by hand and turned it so it would face out so he could put the tire on. I was talking to him and as he did it I noticed the steering wheel freespin very quickly, as one would expect, as he turned it. It locked in place, as would be expected. We finished the job and test drove it after. All seemed fine. My question is, could the steering wheel spinning so fast with the truck not started have caused any unseen damage?
I tend to worry too much when it comes to vehicles, I am aware.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Brake pads and rotors [Re: mobilaltima] #5292010 12/12/19 12:39 AM
ctechbob Offline
I wouldn't worry about it at all.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Brake pads and rotors [Re: mobilaltima] #5292039 12/12/19 02:48 AM
Char Baby Offline
I doubt that any harm was done as I've done the exact same thing 100s of times. ATMOF, this is how I bleed out air after flushing/replacing P/S fluid.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Brake pads and rotors [Re: mobilaltima] #5292058 12/12/19 04:24 AM
T
tcp71 Offline
T
2012 f150 has electric power steering. The controller can be finicky about work done without the battery being disconnected. If you didn’t get any warnings or a CEL with PS codes thrown, you got away with it. There is no fluid in the system.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Brake pads and rotors [Re: mobilaltima] #5292182 12/12/19 08:05 AM
Astro14 Offline
This isn’t about pads and rotors, it’s about moving electric steering.
And it’ll be fine.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Brake pads and rotors [Re: mobilaltima] #5292479 12/12/19 01:26 PM
N
nthach Offline
N
No harm done. The EPS assist motor is separate from the rack or column and you have to be able to turn the wheel in the event of an assist system failure.
Where there is a spiral cable in the steering column for the airbag and wheel-mounted controls, they are damaged only if the steering shaft turns without being mounted to the steering gear or if the cable isn't recentered prior to reinstall.
