Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
115 registered members (2011335d, 928, 1978elcamino, 11 invisible), 3,983 guests, and 24 spiders.
Topics300,352
Posts5,173,979
Members70,491
Castrol Engine Shampoo (Oil Flush) #5291948 12/11/19 10:03 PM
A
adams355 Offline OP
A
Any thoughts on this?
It's a different formula compared to most engine flushes
https://www.castrol.com/en_au/australia/products/other-products/engine-flush.html
Not available in the US I have heard
Interesting claims by another site promoting it especially number 3
Key feature
-Remove sludge and dirt from engine parts
-Help maintain engine power & efficiency
-Prevent contamination of fresh oil by residues left behind
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/26593633723740AD802582A3000B23C9/$File/BPXE-AWEALM.pdf
https://msdspds.castrol.com/ussds/amersdsf.nsf/Files/7E1DE5C7D98A20878025827F00529953/$File/11346105.pdf
2007 Ford XR6 Turbo (modified) - Shell Helix Ultra 5W-40 SN A3/B4 - Purolator ONE filter + ZF 6 speed - Gulf Western SYN-TS
2008 Holden Craptiva (wife's) - Castrol 5W-30 A3/B4 - Shell R next
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5292068 12/12/19 04:47 AM
demarpaint Offline
I guess we'll have to wait for the reviews from OZ, to know if it works or not.
God Bless Our Troops
Re: Castrol Engine Shampoo (Oil Flush) [Re: demarpaint] #5292105 12/12/19 06:27 AM
A
adams355 Offline OP
A
I used it, it's a very different flush, it is oil not a watery liquid like other flushes. 11.0 at 100C, so it's not thinning your old oil. I'm just unsure of the active ingredients, what they are and how they work. They are in the msds. My engine is pretty clean but I usually run a flush so I know the turbo oil lines are free of any build up.
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5292188 12/12/19 08:10 AM
R
Rat407 Offline
R
I guess they needed this to combat all the issues caused by running heavier weight oil unlike the 0w-20 here in the US.
2002 Silverado 5.3 0w-20 AMSOIL®
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5292189 12/12/19 08:10 AM
Donald Offline
Why not fill oil sump with 50% oil and 50% diesel?
2015 Ford F-250 w/Powerstroke
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5292237 12/12/19 09:07 AM
A
adams355 Offline OP
A
Its an oil, it's not common engine flush.
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5292344 12/12/19 11:18 AM
P
paoester Offline
P
No, the MSDS doesn't identify any active additives, just about 90% base oil diluent.
They say it doesn't have solvents, so then what? Something has to dissolve the sludge, as 10% of the mixture. No evidence it does anything but drain your wallet.
Run Valvoline Premium Blue Restore 10w30 every 50,000 miles for a full oil change interval in the summer if you want cleaner piston rings. Patented PAO+POE+AN+whatever. Very stable, tough oil to run. ...
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/499589
https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/printthread/Board/1/main/316395/type/thread
Re: Castrol Engine Shampoo (Oil Flush) [Re: Rat407] #5293146 12/13/19 06:22 AM
K
Kamele0N Offline
K
Usually flushing oils are in sae30 or sae20 grade smile So US of A grades.... :P
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Castrol Engine Shampoo (Oil Flush) [Re: paoester] #5293201 12/13/19 07:58 AM
M
Mad_Hatter Offline
M
Doesn't answer the "what's in it" question but you can't rely on the MSDS disclosure for all the ingredients.
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5293442 12/13/19 12:02 PM
PimTac Offline
Iā€™m curious about the name. Shampoo comes across odd. Shampoos are usually external cleaners.
Internal cleaners would be called enemas but I can see why Castrol would shy away from labeling it as such.
Why not call it a engine flush?
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Castrol Engine Shampoo (Oil Flush) [Re: PimTac] #5293487 12/13/19 01:05 PM
M
Mad_Hatter Offline
M
I actually like the way "engine enema" rolls off the tongue.šŸ˜‚
Re: Castrol Engine Shampoo (Oil Flush) [Re: Mad_Hatter] #5293513 12/13/19 01:30 PM
P
paoester Offline
P
... "High Colonic Castrol" or HCC, works here.
And every shampoo has to have a conditioner. I can imagine them marketing "clean", then "condition" your internal parts with our sister product. Suckers buy two!
Re: Castrol Engine Shampoo (Oil Flush) [Re: paoester] #5293840 12/13/19 08:57 PM
M
Mad_Hatter Offline
M
šŸ˜‚šŸ˜‚šŸ˜‚šŸ‘
Re: Castrol Engine Shampoo (Oil Flush) [Re: adams355] #5295581 12/16/19 01:51 AM
ChrisD46 Offline
*Why not just use Seafoam (1 oz. per qrtt. of oil) for 100 miles right before the next oil drain & fill ? ... Has anyone heard of Seafoam damaging engine components or seals run at the proper dosage & miles (300 miles max) ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Castrol Engine Shampoo (Oil Flush) [Re: ChrisD46] #5295823 12/16/19 09:55 AM
M
Mad_Hatter Offline
M
Seafoam is spendy..I can do the same at a fraction of the cost using MMO.
