2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
62 registered members (2000ltdken, bdcardinal, AndyB, 2strokeNorthstar, ArrestMeRedZ, BBDartCA, 5 invisible), 1,580 guests, and 18 spiders.
Topics300,449
Posts5,176,028
Members70,506
Put the winter tires on the Impala today. #5291813 12/11/19 07:31 PM
J
JimPghPA Offline OP
J
I put the winter set (all 4) of Bridgestone Blizzaks on our 2001 Impala today. I have both the summer set of tires and the winter set on their own steel rims so I do not have to have tires unmounted and mounted and balanced with each change of season.
I found out that the drivers front rim has a bunch of grease on the inside of the rim of the summer tire that came off. So the boot for the CV joint is bad. The CV joint is not making any noise, but it will not pass inspection that is due at the end of April with a bad CV boot. I guess I will drive it until then to get more miles out of it if it dose not start making any noise before April.
The drivers rear tire had a drywall screw in it. At least it is near the center of the tread so it is repairable. The head of the screw is sticking out and half worn off from contact with the road. So it must have been in there for a while, but the tire was not loosing any air. The summer tires including this one still have plenty of tread so I will go with a plug to fix it, and see if it holds pressure while in winter storage.
I stopped at the Alternator and Starter shop that put the new Interstate battery in the car three weeks ago under warranty, after the last new one failed after only 12 days of use, and had them do a load test on the new battery. He loaded it down to draw 350 Amps and it tested good.
I thought that getting the Blizzaks on the Impala would be all I had to do to get it ready for winter, but now I'll have to pay attention to weather that CV joint starts making any noise.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5291827 12/11/19 07:50 PM
V
volk06 Offline
V
Is it just leaking out of the end of the boot or is it torn? Could try the trick of putting a zip tie or hose clamp on it to prevent further loss of grease to help it make to April.
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5291857 12/11/19 08:24 PM
P
propuckstopper Offline
P
Are you sure you want to drive it through winter with a broken CV boot? Why not fix it now, before any damage is done? Seems like the cheaper route to me.
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5291890 12/11/19 08:58 PM
J
JimPghPA Offline OP
J
I stopped by my mechanics shop today and showed him the tire with the rim with all the grease on the inward side of the rim, and asked him about just replacing the boot. He said the boot repairs do not hold up. He said it is best to just replace the CV joint. I mentioned it is not making any noise and and as long as it is not making noise I might as well get some miles out of it before it has to be replaced for inspection.
Volk06, I will get him to put it up on his rack to see if a zip-tie or hose clamp at an end of the boot can help.
JimPghPa
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5291914 12/11/19 09:19 PM
J
John_Conrad Offline
J
i did a boot replacement and it didnt last for me either, drive it till it goes
or as close to it
Safety doesn't happen by accident.--author unknown
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5291958 12/11/19 10:25 PM
daves87rs Offline
I would replace the CV joint soon.......
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292070 12/12/19 04:53 AM
L
Lapham3 Offline
L
I remember the early days when the front wheel drive stuff started coming in. The darn OE boots didn't last as long as they should have. The 'quick boots' came in and worked ok, but you had to be very clean and careful to get them glued well. The OE boots are much better these days, but maybe you could still source the quick boots.
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292099 12/12/19 06:05 AM
sdowney717 Offline
Boot repairs hold up fine if the CV joint metal is not worn out. If you wait too long, water and road grit will get into the CV joint, but that can take a long time. I just rebooted 2 outer boots on our 96 Trooper which had been ripped for maybe a year. While there was some grit in the area near the tear, the joint was still fine. But it is cheaper for you to have a mechanic replace the whole axle then pay them to do a boot. It's a lot cheaper for me to do my own boot replacement vs buy an axle, so that is why I do it.
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292119 12/12/19 06:50 AM
K
Kira Offline
K
Really a good day.
You got your snows on.
You discovered the screw and avoided being surprised by a flat.
You saw you have a leaking boot and can take appropriate action.
For an '01 vehicle, it might just pay to do the entire CV axle swap as suggested.
I spotted a torn boot and injected grease into it for 1.5 years. It never made a sound.
When the time came I replaced the effected axle, both ball joints and lower control arms.
I had poly bushings installed on a jump set of arms I found at a junkyard.
Years later I sold the vehicle easily.
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292123 12/12/19 06:54 AM
caprice_2nv Offline
I love those Impala's after my short 6 month career as a part time night shift taxi driver. Very comfortable, decent handling car and the 3800 is awesome and can apparently handle 60k mile oil changes.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Put the winter tires on the Impala today. [Re: propuckstopper] #5292169 12/12/19 07:57 AM
W
WyrTwister Offline
W
Yep , replace the boot .
Wyr
God bless
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292174 12/12/19 08:01 AM
Donald Offline
The main thing a car does for you is to test your patience.
2015 Ford F-250 w/Powerstroke
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292235 12/12/19 09:05 AM
U
UG_Passat Offline
U
Split CV boot kits that you have to glue together don't hold up, since that joint will always be a weak point.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Put the winter tires on the Impala today. [Re: propuckstopper] #5292251 12/12/19 09:35 AM
JohnnyJohnson Online Content
Online Content
Yep
[Linked Image]
2004 Corolla 138441
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Put the winter tires on the Impala today. [Re: JimPghPA] #5292336 12/12/19 11:12 AM
slacktide_bitog Online Content
Online Content
You are so lucky!!
Because GM still sells all-NEW non-reman axles for your Impala happy
You MUST use OE NEW whenever possible because Cardone "rebuilds" are trash and are done poorly and half-hearted and most of the time just slap a new boot on, and worse, their new boot is neoprene which is inferior to the OE thremoplastic mad
Rock Auto has them at a good price smile
