Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
25 registered members (4WD, blufeb95, ctechbob, CB22, carlprop, 5 invisible), 729 guests, and 36 spiders.
Topics300,451
Posts5,176,077
Members70,506
Tires or Toyota ABS #5291740 12/11/19 05:33 PM
F
ford46guy Offline OP
F
My Lexus has tires that came with the car - Uhh... Not a famous brand. Ironman Imove. But I left them because the online ratings are decent. In dry and wet they are fine. They seem pretty hard and have no sipes (like the LTX for example on my explorer)
When the snow started falling, I tested things out on streets with no traffic, and was able to slide thru stopsign intersections with pretty good stopping distance. (Again, no cars, anywhere, suburban dead end streets).
Now, I want to blame the tires but, is toyota ABS too aggressive in the snow? Also, it is an AWD car with full time center planetary diff, that can lock up, but I'm not really impressed.
I wonder if tires can make such a difference.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Tires or Toyota ABS [Re: ford46guy] #5291750 12/11/19 05:57 PM
supton Offline
No siping? I'm guessing that and a compound that is hard in cold temps is the problem.
Can't comment otherwise, I'm sure Toyota uses a different ABS system (and programming) per model. I can't say I've had problems; I usually have snows or a set of RT43's on, and it's just not a valid comparison. [RT43's aren't snow tires, but when I use them in snow, I'm far from aggressive, and don't expect much.]
How old are the tires? I'm guessing not too old, but if they are more than a 2 or 3 years old, it might not be bad money to get a better set of all seasons (if not winter tires).
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Tires or Toyota ABS [Re: ford46guy] #5291753 12/11/19 06:04 PM
Skippy722 Online Happy
Online Happy
I had Ironman imove tires on my 300. They were straight up dangerous in the snow. But like what you said, they were fine in dry and wet weather. I replaced them with some RT43’s which are significantly better in the snow.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Tires or Toyota ABS [Re: ford46guy] #5291757 12/11/19 06:07 PM
R
Rand Offline
R
Tires are everything. Try one of the newer all-weather styles if winter traction is important and you dont want to run winter tires.
Re: Tires or Toyota ABS [Re: ford46guy] #5291780 12/11/19 06:43 PM
M
Mercury321 Offline
M
Vredestein Quatrac 5's might fit your needs. Great reviews on Tire Rack.
Re: Tires or Toyota ABS [Re: ford46guy] #5291811 12/11/19 07:29 PM
1
14Accent Offline
1
ABS is purely a function of wheel lock. Wheel lock is purely a function of available traction. Crappy tires=less traction=more ABS activation.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Tires or Toyota ABS [Re: ford46guy] #5291822 12/11/19 07:46 PM
Astro14 Offline
Tires make a huge difference.
And you should get new ones!
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Tires or Toyota ABS [Re: 14Accent] #5291839 12/11/19 08:01 PM
F
F
I read that some ABS systems just don't work that great in the snow.
The ABS on the Grand Marquis seems to work much better, the traction control, even though it is RWD, is pretty good in the snow.
I have continental true contact though (about 1/2 tread). Maybe it is the tires though in this case.
Re: Tires or Toyota ABS [Re: ford46guy] #5291847 12/11/19 08:16 PM
M
maxdustington Offline
M
You can slide around on a car with ABS with junk tires. That's why you need snowies on both axles.
99 Toyota Tercel CE 5EFE/C151
Re: Tires or Toyota ABS [Re: Astro14] #5291851 12/11/19 08:20 PM
F
F
I agree, I may get snows and use these for the summer. I don't think it is the car (this is a 2013 but from what I understand they are very similar):
Re: Tires or Toyota ABS [Re: ford46guy] #5291859 12/11/19 08:26 PM
svhanc Offline
My Tacoma came with factory Dunlops that were terrible in the Dry and Wet, but were dangerous in snow. The lack of traction combined with sensitive ABS would make me not stop at all. I had to leave the truck in gear and just idle up to stop signs. I left them on for a few years but I would pull the ABS fuse every winter.
Replaced them with Michigan LTX and have never had a hint of a problem again.
Money in tires is money well spent.
2010 Toyota Tacoma 4x4 2.7 5spd ([email protected]&Fram [email protected])
2001 Jeep Cherokee XJ 4.0 Auto ([email protected]&Fram [email protected])
2007 Suzuki SV650N
Re: Tires or Toyota ABS [Re: ford46guy] #5291882 12/11/19 08:49 PM
Driz Online Content
Online Content
Anytime you see a name like Ironman or Dura🙄🙄🙄 you always gotta wonder just how much Chinesium🤡 is in them. Who puts 5th rate tires on a Lexus anyways? Isn’t that some kind of sacrilege . In Albany of all places. Better get ya a set of Blizzaks shoes like I just stuck on my Camry today. Winters just getting started..........
Re: Tires or Toyota ABS [Re: ford46guy] #5291895 12/11/19 09:03 PM
R
Rolla07 Offline
R
Hmm...my new to me Venza AWD, i put on conti wintercontact SI's...my first winter driving the Venza...the abs kicks in pretty quickly when i step even a bit firmly or it senses slipping...im used to driving an 07 Corolla... i do like that the abs keeps me straight but id likely rather not have ABS. Oh well.
What exactly happens? Does the peddle pulsate like the ABS kicked in early? If so, it even happens with my dedicated snows..im learning to brake very gently..lol
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Tires or Toyota ABS [Re: ford46guy] #5291995 12/11/19 11:42 PM
E
edyvw Offline
E
You can have brakes on your vehicle strait out of Formula 1, best shocks, best suspension, AWD 10 light years ahead of everyone else, but if your tires are bad, nothing of that matters. Brake force is transferred by tires, torque during acceleration is transferred by tires.
You can have all safety features in a vehicle, 100 airbags, blind spot monitors, auto braking, but THE MOST important safety feature are tires!
And yes, your problem are tires, siping or not, compound on those tires is getting to hard duing cold weather.
Get decent tires like Michelin, Bridgestone, Continental, Pirelli etc. You might think after you bought brand new car.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Tires or Toyota ABS [Re: Rolla07] #5291998 12/11/19 11:45 PM
E
edyvw Offline
E
My SIenna is not behaving any differently than any other vehicle. I have Michelin X-Ice Xi2 on it now, and I ahd same tires on BMW X5 in winter. ABS is behaving same, tires are behaving same. Though ESP on Sienna is ridiculously intrusive.
