Wait until you see who's driving...
by Shannow - 04/05/20 06:57 AM
Getting My Harley Back On The Road
by Silverado12 - 04/05/20 06:45 AM
Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
London, Dave66, Kurt_Kent_09, northestPM, dgvu89
71102 Registered Users
98 registered members (AndyB, Aredeeem, 2004tdigls, 2015_PSD, 53' Stude, 4WD, 11 invisible), 2,062 guests, and 16 spiders.
Topics303,618
Posts5,238,451
Members71,102
Page 1 of 4 1 2 3 4
Confused. Mercon V or Dexron VI? #5291613 12/11/19 03:33 PM
AcadiaDave Offline OP
Subject at hand: 2011 GMC Acadia Denali AWD. 6T75 auto trans.
Had my engine oil changed today, and asked the shop to fill/drain the trans oil at the same time. Job done, went to cash out and the paperwork said MERCON V used, instead of GM spec’d DEXRON VI. Knowing next to nothing about AT feeding and care, I stopped dead and asked “isn’t that for Ford transmissions?” Service writer said it came from the Cadillac store in their dealer network, and that it was “the same.” Doubtful, I pulled up my pdf of the owner manual and it specs out DEXRON VI. No mention of MERCON V at all.
Can someone please confirm that one is the same/same enough as the other? Reading a bit I found that the GM 6T and the Ford 6F series trans are a joint venture, so maybe that was the basis of their assertion?
Any help would be appreciated.
Dave
2011 Acadia Denali AWD
2010 Ford Ranger XLT
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291619 12/11/19 03:41 PM
E
eljefino Offline
E
It's close, but since it isn't on-spec, I'd make them redo it with the right stuff. If for no other reason than they should have asked you/ had your informed consent.
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291631 12/11/19 04:04 PM
A
A_User55555 Offline
A
Maybe they used one of those Dexron VI/Mercon V blends. Supertech has one and it's Dexron Approved.
If this was a GM Dealer, I doubt they would put the pure Mercon V fluid.
2011 Cadillac DTS. No the headgaskets have not blown.....
5W-30 Valvoline Full Synthetic with a Purloator Boss PBL25288 Filter
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291651 12/11/19 04:26 PM
J
JayhawkRoy Offline
J
Here's what Super Tech says about their Mercon V and "suitable for use":
Super Tech MERCON V Automatic Transmission Fluid, 1 Quart:
Uses a unique combination of conventional base stocks and an advanced additive technology
Meets the performance requirements of Ford automatic transmissions calling for MERCON V fluid
Suitable for use where the following automatic transmission fluids are recommended:
Chrysler 3 and 4 (except C-604 transmissions)
DEXRON II (E, F)
DEXRON III (G, H)
DEXRON VI
Honda Z-1
MERCON
MERCON LV
MERCON SP
Nissan Matic-J
Toyota T-IV or Toyota WS
Not for use in vehicles requiring Ford Type F fluid or Continuous Variable Transmissions (CVTs)
Super Tech transmission fluid provides protection against wear and transmission shudder
Resistant to thickening due to high temperatures
Provides friction stability to maintain smooth consistent shift performance
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291658 12/11/19 04:32 PM
M
Miller88 Offline
M
Isn't that transmission used in different Ford products anyway? I guess those would be mercon LV though.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Confused. Mercon V or Dexron VI? [Re: A_User55555] #5291659 12/11/19 04:32 PM
W
Wolf359 Offline
W
Vavoline Maxlife ATF is also one of those crazy Mercon, V, LV and Dextron II, III, VI fluids among others all in one fluid.
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291665 12/11/19 04:43 PM
J
Jetsfan421 Offline
J
Mercon v is not the right fluid in any gm product ever. You need to go back and have them replace it with a dexron VI equivalent. Mercon lv is acceptable, and so is maxlife. It shouldn't have hurt anything, but for longevity and peace of mind they should make it right.
Re: Confused. Mercon V or Dexron VI? [Re: Jetsfan421] #5291678 12/11/19 05:08 PM
CharlieBauer Offline
Agreed. Since GM recommend a licensed Dex VI product, that's what should be used. Mercon V is most definitely not Dex VI.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Confused. Mercon V or Dexron VI? [Re: CharlieBauer] #5291699 12/11/19 05:36 PM
That’s what I’ve done. It never left the shop, actually. Had them get the correct fluid and drain and fill ALL of it.
Dave
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291715 12/11/19 05:57 PM
B
BlakeB Offline
B
Are they doing a cooler line exchange or just a drain and fill?
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291719 12/11/19 06:01 PM
B
bullwinkle Online Confused
Online Confused
B
Also, Mercon V is normally a blend, Dex VI is a FULL synthetic. I'd be a little worried if a garage messed up something that simple, I'd be looking for another shop. Funny thing is, Merc V is a lot rarer than Dex VI, and seems to normally cost more!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Confused. Mercon V or Dexron VI? [Re: AcadiaDave] #5291738 12/11/19 06:24 PM
J
Jetsfan421 Offline
J
I'm not sure a drain and fill would get all of it out after it's been run. Pretty sure it takes at least 3 drain and fills on that particular transmission to get most of the fluid renewed.
Re: Confused. Mercon V or Dexron VI? [Re: BlakeB] #5291802 12/11/19 08:21 PM
Sounded like a cooler line exchange, the service writer said “flush.” I insisted on all of it being replaced, so if ill things happen after this it’s on them - I made that clear as well.
Dave
Re: Confused. Mercon V or Dexron VI? [Re: Jetsfan421] #5291804 12/11/19 08:22 PM
I’ll be doing a drain/fill the next couple oil changes just to be certain.
Dave
Re: Confused. Mercon V or Dexron VI? [Re: Miller88] #5291817 12/11/19 08:37 PM
It’s that joint Ford/GM project unit. Ford calls theirs 6F, GM 6T. So probably, but it’s had Dex-VI in it as long as I’ve had it.
Dave
Page 1 of 4 1 2 3 4
