Washing coolant down a storm drain?
by jharrison - 02/22/20 12:57 AM
storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
31 registered members (carlprop, ChiTDI, 2013ecof150, Bailes1992, c502cid, Cdn17Sport6MT, 1 invisible), 1,306 guests, and 19 spiders.
Topics301,769
Posts5,202,391
Members70,775
Sick and tired of these Ford (exide?) batteries #5291298 12/11/19 09:47 AM
BeerCan Offline OP
I cleaned and dressed this battery 2 weeks ago and look at it. I'm getting ready to dump these batteries for something else. This is ridiculous.
This is a known issue on the ford super duty driver side batteries. If you have one and have not checked it you better.
[Linked Image]
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291311 12/11/19 09:57 AM
CharlieJ Offline
I think the oiled felt battery washers will prevent this. I believe the cause of the battery corrosion is caused by gases leaking past the plastic and lead battery terminal. The oiled felt is suppose to keep the gas at bay. That's the theory anyway. I had a battery that was starting to do this, after cleaning the terminal and adding the washers, it did not come back. Oh, and that was on a Deka battery, so it can happen to any brand.
'07 Mazda3 2.3 : Shell Rotella Gas TRUCK 5w-30
'84 Mazda Rx-7 : Valvoline Maxlife 10w-30
Re: Sick and tired of these Ford (exide?) batteries [Re: CharlieJ] #5291319 12/11/19 10:02 AM
K
khittner Offline
K
Try a spritz of terminal anti-corrosion spray. Permatex or CRC, at your FLAPS, or on Amazon. I don't know what you "dressed" the cleaned terminal with, but it's not the characteristic bright red that I've seen from these products, which do fine on all of my Sam's Club Duracell/East Penn batteries.
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291324 12/11/19 10:05 AM
R
Rand Offline
R
looks like its either an exide or someone over tightened the terminal at some point in its life
I'd ditch it before it eats your battery cables and you have to replace those too.
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291327 12/11/19 10:09 AM
bdcardinal Offline
If it is a Motorcraft battery it is Johnson Controls. Either the black label factory installed ones or the red label service replacements.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291337 12/11/19 10:15 AM
BeerCan Offline OP
These are factory batteries in the 2017 F250 in my sig. I've cleaned, wire brushed and used preventative spray multiple times. I should have took a picture when I first found it, it was all the way up the harness.
[Linked Image]
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291343 12/11/19 10:20 AM
SatinSilver Offline
Time to clean again and as mentioned use the felt battery washers. I went through this with an Exide battery and those washers kept the build up at bay. Got 5.5 years out of it and it was still working when I replaced it. The battery was only $55 at Rural King for a group 35.
The NOCO battery treatment kits or just the washers are only a few bucks at WM.
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291345 12/11/19 10:23 AM
Donald Offline
Its a Johnson Controls by the shape of battery cell cap.
2015 Ford F-250 w/Powerstroke
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291349 12/11/19 10:26 AM
Donald Offline
I think the other way the post seal can be broken is by NOT using a terminal puller and trying to twist off the terminal from the post.
Certainly no reason not to try a felt washer. If it does not work you are only out $2 or $3.
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291364 12/11/19 10:39 AM
Chris142 Offline
Try to find batteries that don't have those vent caps on the top. Look for the ones with vents on the sides and a sealed top.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Sick and tired of these Ford (exide?) batteries [Re: Donald] #5291409 12/11/19 11:06 AM
CR94 Offline
Yes. Every battery I ever had that was made by Johnson (branded by Walmart and Autozone) did this. The RK one from Exide, the Panasonic, and the Kmart one made by Delco did not.
2011 Toyota Prius now at 109K
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291451 12/11/19 11:41 AM
N
nthach Offline
N
For some reason, JCI batteries puke acid and corrode like no other. I took the advice of someone here who touted RP-342 for batteries and I coated the terminals on a Subaru I maintain with it. The car has a Costco Interstate in it.
I might have the parents get a AAA Deka replacement for their van, it's approaching the 4th year of service. Or maybe the Hyundai Sungwoo made Everstart from WM.
Re: Sick and tired of these Ford (exide?) batteries [Re: nthach] #5291498 12/11/19 12:22 PM
Donald Offline
I thought all cars in Calif were required to be electric or hydrogen or plutonium. Just not gas or diesel.
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291568 12/11/19 01:30 PM
J
joegreen Offline
J
I work at Enterprise rent a car and I have only seen corrosion like that on Nissan's with the batteries made by jci. These are brand new cars and the batteries are leaking acid out of the caps. It has been happening for as long as I have worked there. Every time I pop open the hood especially on the altimas I expect to see that blue corrosion. I take a hose to the corrosion and top of battery but it will be back soon. Here are some pictures of an Altima before and after I hose it off. Took this picture last week.
[Linked Image]
[Linked Image]
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Sick and tired of these Ford (exide?) batteries [Re: BeerCan] #5291585 12/11/19 01:44 PM
2015_PSD Offline
The post seals are leaking. Both of the batteries in my 2015 PSD had to be changed within 6 months (under warranty). The second set did not leak.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
