Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Personal finance book in Spanish
by czbrian - 01/23/20 01:03 PM
SQL Basics?
by tom slick - 01/23/20 11:08 AM
Unused PRO-TEC 101 oil filter cut open / Wix 51515
by rollinpete - 01/23/20 10:32 AM
Mailman1995, DougCFL, Sayafi, SeanSkiVT, 02COBRA
70512 Registered Users
112 registered members (4WD, 53' Stude, 2003f7, 2004tdigls, 2010Civic, 2002 Maxima SE, 11 invisible), 2,387 guests, and 18 spiders.
Topics300,476
Posts5,176,734
Members70,512
295/65/r20 vs 35x12.50r20 weight carrying differences #5291547 12/11/19 01:09 PM
J
J_mo Offline OP
J
The tires on my ram are now 5 years old and nearing 45k miles.
it's about time to replace, and while I'd prefer a 35x12.50r20 for a pair of SOTA 20x10 wheels I bought, I've noticed the 295/65r20 carry a considerable amount of weight in comparison.
Nitto puts them at a 35.45x12.13, rated at a hefty 4080lb per tire.
I pull a heavy 5th wheel so tires and weight ratings are something I do not mess with. .my factory tires are 265/65r20 and are rated at 3640 and have been sufficient for many miles of pulling.
2015 cummins 6.7 - DBL7349- eabp100- M1 5-40 TDT
2006 F-350 6.0 - Lf3656 - eabp110 - Rotella t6 / 5-40 M1 5-40 TDT
2018 Wrangler JL 3.6 (The lady's) under warranty - mopar mo349 - Valvoline Syn 0-20
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5291580 12/11/19 01:40 PM
dareo Offline
It will vary by manufacturer. I have the Michelin LTX in 35 12 50 20 size and it comes in at 3,195 lbs at 75 psi. Same LTX in the 295/65 size is 4,080 lbs at 80 psi. Flotation tires measured in inches somehow have a different "E" range than LT P metric sizes. I'm guessing it is more designed to go offroad than heavy loads.
My goal in selecting this tire was to have the smoothest and quietest ride possible. It is very good at that. Offroad traction is okay, good enough for me since i don't go looking for mud puddles to drive through. I'm happy to trade some off road traction for luxury car ride quality for the vast majority of miles that are on pavement.
You may want to stick with a P metric size for heavy tow.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5292137 12/12/19 07:25 AM
CapriRacer Offline
A word of caution:
P metric (and Euro-metric and Hard Metric) tires - that is, those designated as Passenger Car tires - have to have their load carrying capacity reduced by a factor of 1.1 when used on pickup trucks, SUV's, and trailers.
A 32X12.50R20LT and an LT295/65R20 are both LT designations (one flotation and the other LT metric) and those do NOT have to have their load carrying capacities adjusted for use on pickup trucks, SUV's, and trailers.
Because of this, I think it is a good idea to include the letters in front of or behind the numbers so that it is clear what is being talked about.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5293500 12/13/19 01:21 PM
02SE Offline
You might check the load rating of your wheels, too. Quite a few aftermarket wheels don't have the same load capacity as the tires that fit them. You should find the load rating somewhere on the backside of the wheel.
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5310162 01/01/20 01:58 PM
U
userfriendly Offline
U
Some 35/12.50/20s are now "F" rated with 80 psi instead of "E" rated 65 psi. Flotation sizes are measured by outside gross inflated dimension including tread depth.
I put Toyo CT 295/65/20 on Fuel Cyclone 20X10". The outside dimensions on those wheels is 12.2 x 35.3" . Load rating 129 @ 80 psi, I run them at 65 psi on a 2011 GMC D-Max.
The next size up, maybe in 2 years will be 325/60/20 (likely Nitto EXO) on 20X12" wheels.
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: userfriendly] #5310746 01/02/20 07:27 AM
CapriRacer Offline
Originally Posted by userfriendly
Some 35/12.50/20s are now "F" rated with 80 psi instead of "E" rated 65 psi. ….
I know that statement will confuse quite a few people. What userfriendly stated is true, and it's a long story why that is so.
CapriRacer
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5311057 01/02/20 01:12 PM
U
U
CapriRacer;
After posting, I thought you might catch my error;
295/65/20 load rating [email protected] psi, should be;
load rating 129
max pressure 80 psi
My tires had to be seated with starter fluid.
By installing the tires on the max recommended 10" wide wheels, sidewall flex is reduced and the tires should run cooler.
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5311325 01/02/20 05:22 PM
U
U
Another size I'm contemplating next time around is 35/13.50/20 also "F" rated 80psi cold max on 12" wide wheels.
Finding 20X12" zero off-set wheels is hard without springing for custom forged.
I need fender flares for what I have now, as mud & snow showers the side of the truck including the mirrors.
Those monster lifted trucks with negative off set 14" wide wheels are pavement princesses.
