Honda hcv160 push mower. Air filter cleaned as this mower was bought new this sesson
Out: factory supplied oil
In: Royal purple HPS 10w30
Craftsman snowblower with 5.5hp Tecumseh motor
Out: unknown black oil (flushed with entire quart or Mobil super synthetic 0w20. Oil was very clean after flush)
In: Rotella gas truck 5w30
Both filled with ethanol free (rec fuel) and ran for several minutes and oil level checked.
Originally Posted by Astro_Guy
Originally Posted by Macsignals
It will only run reliably on partial choke, will be draining/washing the gas tank and changing the shutoff valve, filter and lines soon. If that fails then an Amazon carb is going on.
Have you considered running a fuel system cleaner through it? Something PEA based like Redline SL-1. It might be worth a try if you already have some. A Wawa station out my way just started selling Ethanol free gas, and I am thinking of using it in everything that sits idle for long periods. That includes the generators.
If that's a Briggs metal carb, they are pretty easy to take apart and clean. I just did one on a Toro mower and it had a plugged main jet. You may just be able to unscrew it from the bottom of the carb bowl (looks like a drain plug) and run a wire through it. Most of the times you just need to clean the carb but don't know what you have. If it's a Nikki (worst design I have ever seen) they are more temperamental but still not hard to take apart and clean.
in my pressure washer, Honda GCV160 motor, 10w30 Motorcraft blend with a few ozs of Castrol HD30. Same in my Subaru 175 motor on my Mower,closer to 2/3 Moto and 1/3 HD30. No oil filter on either.
6.5 LCT engine on the log splitter. Drained 20 ounces STP 10/40 replaced with Mobil 1 10/30 for easy winter pull starts. I really like the engine. Roller bearings on both sides of the crankshaft. Smooth running easy starting. Great on fuel.
Craftsman 29" snowblower - 11.50 TQ Briggs and Stratton OHV
Out: 3 year old Supertech 5w30 (last time serviced)
In: Castrol 0w40
Replaced head gasket (reason for service). Had a blown head gasket from overheating. Had a mouse nest in the blower housing and customer did not notice.
Also adjusted governor, since it was running at 2600 RPM (fixed throttle engine, no throttle lever).
I stock many flavors of ope oils. I work on many out of my garage. The usual sae30(both ND and hdeo), 10w30hdeo, 20w-50. Also syn in 0/5w-20, 5w-30, 15w-50 and 20w-50.
My personal fleet sees everything from syn 0w-20 to sae40. Most usually see what the car sees, usually syn 0/5w-20.
Left the filter on, run them for two changes typically.
Out: 5w40 Mobil Delvac 1
In: Remaining leftovers of 10w30 Valvoline Premium Blue SB HDEO, 5w30 QSUD and 10w30 Meijer/Warren Oil Full Synthetic. If my math is right based on the amounts used it's about 8w30 mixed brew.
Billy Goat leaf vacuum with Honda GSV190. New machine this fall; estimated 8-10 hours. The manual calls for 10w-30.
Out: Factory/Dealer fill. Whatever it was, it ran out like water. I am having a hard time believing that it was any type of Xw-30.
In: 10w-30 Mobil1 High Mileage (3.5 HTHS)
This machine requires some strength for a long slow pull to start. It should be interesting to see how hard that rope is to pull the next time out.
