Penzoil Platinum 100% Synthetic ????
Iowa City
I recently saw posts from users that said Penzoil Platinum is a 100% synthetic oil. The implication is that it is 100% PAO or PAO/Ester blend, not a Group 3 Hydro-cracked petroleum oil.
I know there are well known 100% synthetic lubes on the market, such as Redline, Amsoil, Royal Purple, etc. Is PP a true 100% synthetic oil?
This horse has been kicked around quite a bit. By US definition of synthetic oil it is, so I guess it is.
I believe in the U.S. "synthetic" as it pertains to engine oil is a marketing term and not a legal definition. Oil mfgs here in the states can't seem to agree on a definition of "synthetic". Some say grp3's are so altered from their original form after processing that they should be called synthetic, the other side of that debate thinks otherwise and wants to reserve use of the term for grp4 and above.
So I guess the real question is what side of that debate do you fall in?
Pennz Plat has no PAO according to Safety Data Sheets which normally have to name it. (They don't have to name esters, oddly enough, for health-safety reasons I don't understand.)
So its Group3+ GTL with maybe some esters to help out.
The NAD decided Group3/3+ can be labelled "full synthetic":
https://www.bobistheoilguy.com/foru...astrol-mobil-court-case-how-it-went-down
I'd just go by what performance specs an oil gets awarded, and not as much by what % of PAO or esters it has. Its interesting though to look at the different approaches companies take.
It appears that oil makers who have access to the most scientists and their fancy intellectual property (patents etc.) making cool effective advanced additives can many times save themselves the higher cost of going all-PAO in their base oils. They can meet the highest performance specs and not have to use much PAO at all.
Group3 or Group3+ base oils can be labelled as "full synthetic" everywhere except Germany, Switzerland, & Austria.
Notice the ~20% mass in a motor oil can be non-syn diluent for the additive chemicals, just to understand.
from a past thread:
Originally Posted by Trav
Quote
found this Total at my vendor store in Germany, the seller in the description says it's a "Synthese technology",
In France and the rest of Europe (except Germany, Austria and Switzerland. A&S were still using the German standard last time i looked in 2011) can call anything synthetic as long as they change the base stock by hydro cracking or maybe other methods.
A true synthetic will have "Full synthetic or vollsynthese" on the container.
The words synthetic or 100% synthetic is no guarantee its anything but reworked dino oil.
vollsynthese is reserved for group IV and V oils but there is a fly in the ointment now, GTL which by definition is a true full synthetic oil and is called group III+.
The question is will German law allow it to be labelled as such?
I have no problem running a modern group III oil at all anywhere as long as i wasn't paying the same or a premium over PAO or ester based oils.
Like i said GTL is an issue, you may find some oils being produced with this base stock but are not labelled "vollsynthese" because of legal definitions.
This is interesting.
http://www.stle.org/assets/document/GTL.pdf
Nope
Wrong
Group 3 is now considered full synthetic. Courts said so.
It is a synthetic just not a high end boutique synthetic.
It is considered a syn oil due to the Group III being changed in the hydrocracking process.
Nope
Wrong
It was the BBB not the court system.
Courts said so.
"Court" strongly implies a government court. No, Judge Judy was not there, OK, got it. Sure it was NAD-BBB, but there were lots of lawyers, evidence, testimonials, opinions, rulings, & with the potential for Mobil to appeal. Sounds like a court at least. Main difference between the NAD-BBB "proceedings" and a civil suit is that Mobil was under no requirement to prove/argue damages of any kind, and the results were not legally binding, unless agreed to ahead of time which I think both parties did anyway.
Originally Posted by Shannow
Found this this morning and thought that it was a good article on WHAT was argued and decided on and by who. http://xtremerevolution.net/a-defining-moment-for-synthetics-by-katherine-bui-lubricants-world-1999/
Don't they make it from natural, as in not synthetic, gas? I'm happy with not knowing more than what is says on the botlte. Eventually there has to be a limit on time spent thinking about lubricating oils for engines.
That depends on how you define "synthetic". I've read both sides of the argument and each makes a compelling case for their position...so you got me. Guess if I had to choose a side of the fence to sit on I'd say grp3's are "synthetic". But at the end of the day I'm not going to lose any sleep over whether I'm right or wrong.
What is the feed stock for PAO production and how is it produced?
Originally Posted by LEADED
I bet you're Engine will not know the difference , move on
who are you calling an engine?
joking aside, I'm more of the opinion of specs are more important than fixating on base oil type.
Originally Posted by aquariuscsm
I think Pennzoil in their Q and A said themselves it's a group 3 oil.
Which is a synthetic oil.
PAOs are made by polymerizing an alpha-olefin molecule like ethylene ...
Ethylene (H2C=CH2), the simplest of the organic compounds known as alkenes, which contain carbon-carbon double bonds. It is a colourless, flammable gas having a sweet taste and odour. Natural sources of ethylene include both natural gas and petroleum.
And Shells GTL ( gas to liquid ) process synthesizes natural gas into a liquid hydrocarbon, which is then processed in a manner similar to crude oil.
So PAO takes crude oil, and processes it into ethylene, then converts it into a synthetic oil product. GTL takes natural gas, converts it into liquid hydrocarbons (oil ), then processes it into a final oil product.
So, which one is truly a SYNTHETIC oil ?
