A moment of silence...😟
by Mad_Hatter - 04/01/20 09:20 AM
Shaving costs during this time
by Bighorn2500 - 04/01/20 08:25 AM
Bosch Premium 3410
by QuangTeo - 04/01/20 03:48 AM
Thicker oils are coming back to USA
by Kamele0N - 04/01/20 03:07 AM
misty air coming out of air hose even with water separator?
by motor_oil_madman - 03/31/20 11:22 PM
Post your favorite racing cars
by IMSA_Racing_Fan - 03/31/20 09:40 PM
Air Filters for Chonda 457cc engine
by 92saturnsl2 - 03/31/20 07:59 PM
Share your Hot Toddy recipe
by LoneRanger - 03/31/20 07:24 PM
Aftermarket CV axle boot replacement
by CDX825 - 03/31/20 06:34 PM
A few discounts at Walmart for buying 2 jugs
by jayjr1105 - 03/31/20 06:20 PM
Bumblebee Ahi tuna poke
by atikovi - 03/31/20 06:05 PM
2007 RDX Differential and Transfer Case?
by maverickfhs - 03/31/20 06:02 PM
Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
Raybestos rotors - Element3 vs Specialty Truck
by RageOfFury - 03/31/20 02:39 PM
Briggs Stratton Quantum engine surging
by alex_at - 03/31/20 12:53 PM
mtnrider, Rickborn, TreyT42, Abi, Transpections
71069 Registered Users
98 registered members (Alfred_B, BAJA_05, 55hambone, Audios, 1978elcamino, aquariuscsm, 9 invisible), 2,051 guests, and 23 spiders.
Topics303,417
Posts5,234,941
Members71,069
Page 1 of 4 1 2 3 4
Come on China. Let's get it right. #5291360 12/11/19 11:34 AM
Chris142 Offline OP
No matter who I buy from or which brand I get they all are from China now. We have had a slew of new radiator failures in the last few weeks. Blown seems mostly.
Been trying to figure out what's causing this.
Today I figured out a way to pressure test the caps pop off pressure on a new radiator. The neck is too tall which won't let the cap vent excessive pressure. Defective radiator!
I plugged the connections on the radiator and put a cap,actually several different brands of cap on it.
It should release @13 psi. I put 25psi on it and it didn't release. I stopped there before my plugs blew out.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Come on China. Let's get it right. [Re: Chris142] #5291406 12/11/19 12:04 PM
W
WhizkidTN Offline
W
Well that sucks!
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (88K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (102K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: Come on China. Let's get it right. [Re: Chris142] #5291417 12/11/19 12:13 PM
B
BMWTurboDzl Offline
B
With so many customers being price sensitive for the part itself I imagine these failures are incredibly annoying.
435i
Re: Come on China. Let's get it right. [Re: BMWTurboDzl] #5291466 12/11/19 12:51 PM
Chris142 Offline OP
Its gotten so bad that I sometimes do the same job 3x. The supplier trys to tell us that its the caps or an engine problem. I can now prove them wrong.
Re: Come on China. Let's get it right. [Re: Chris142] #5291479 12/11/19 01:02 PM
K
KGMtech Online Happy
Online Happy
K
Wow! that's an impressive test set-up. The results should be sent to the head office of each failing cap brand.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Come on China. Let's get it right. [Re: Chris142] #5291480 12/11/19 01:02 PM
bdcardinal Offline
Normally I would say you should switch to using OE radiators, but since you are in the middle of nowhere logistics wise that isn't an option. Wish you were closer, I would at least hook it up on the Ford and Mazda radiators.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Come on China. Let's get it right. [Re: Chris142] #5291493 12/11/19 01:16 PM
ArrestMeRedZ Offline
The body shop I use is forced by insurers to use China parts. They frequently don't fit. When they don't, they bill the supplier for the install and removal labor costs in addition to returning the part.
You should bill the supplier for your labor costs. Since it's happened more than once, bill for the troubleshooting and test time also.
Re: Come on China. Let's get it right. [Re: ArrestMeRedZ] #5291496 12/11/19 01:18 PM
SatinSilver Offline
I'd rather have a used oem part. Even for a fender that's a different color. If the shop is good they will prep, prime and paint it properly. And the fit should be spot on.
Re: Come on China. Let's get it right. [Re: Chris142] #5291517 12/11/19 01:42 PM
diyjake Online Content
Online Content
That is very creative test method!
What vehicle was that for?
Re: Come on China. Let's get it right. [Re: bdcardinal] #5291522 12/11/19 01:45 PM
Chris142 Offline OP
Our customer base wont pay that price. They only want the cheapest stuff and will walk for $1.
Re: Come on China. Let's get it right. [Re: ArrestMeRedZ] #5291523 12/11/19 01:45 PM
slacktide_bitog Offline
The worst part is that Denso is an OE supplier and makes so many OEM radiators in the US and Japan, but they won't rebox those OE filters for the aftermarket smirk2
They used to make the aftermarket radiators in Taiwan at their subsidiary Cryomax, and those radiators are good quality, but they stopped using Cryomax Taiwan. and started using China for their aftermarket radiators mad mad
It appears only Ford, GM, and the Europeans still offer easily-attainable OE quality radiators.
Nissens makes most of their radiators in Denmark, if you're lucky enough to find one
approved
Re: Come on China. Let's get it right. [Re: diyjake] #5291524 12/11/19 01:47 PM
Chris142 Offline OP
Those are the plugs that we test radiators with. I modified one to use as the air source. We normally use the radiator cap spot to put air in it. But since I needed to test the radiator and cap together I used that thing.
Re: Come on China. Let's get it right. [Re: Chris142] #5291537 12/11/19 01:59 PM
P
PandaBear Offline
P
How's Denso retail Chinese quality?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Come on China. Let's get it right. [Re: Chris142] #5291541 12/11/19 02:00 PM
bdcardinal Offline
Sometimes it is best to fire a customer.
Re: Come on China. Let's get it right. [Re: bdcardinal] #5291625 12/11/19 03:50 PM
Chris142 Offline OP
We would be out of business! It's the entire area and not just a few people. Remember that I'm very close to our southern border and most of the people that came from south of us are still in a poverty mind.
Page 1 of 4 1 2 3 4
