Valvoline High Mileage vs Valvoline Full Synthetic?
Rhode Island
Why would one go for the maxlife vs the regular full synthetic oil? Is there really a need for high mileage synthetic?
Originally Posted by Bettez88
So there is really no point in using high mileage synthetic then is what you're saying
Can you really prove a concrete benefit(not really). There may be more or less of an additive, but its mostly marketing. No manufacturer is suggesting it, and some have extended warranties to 120K.
So it is like the engine will go to 350K with the HM and 300K with the synthetic? Even they can't make that claim.
One can argue it swells seals a bit but eventually they fail harder (may or may not be true).
No different (to me) than saying a laundry detergent gets clothes 49% brighter than the competition.
It is more a feel good thing.
Greater detergency/dispersants
Thicker oil to combat blow by
More AW additives
More seal conditioners
Higher TBN, Pennzoil for example has a +9 tbn
Esters for cleaning things like the rings and valve guides
Low(er) volatility to combat consumption
Not every HiMi formula fits this bill so you have to check out the PDS.
Seals are usually silicone rubber these days, about widespread post-2002 or so, meaning any extra seal conditioners (high mileage oil's main thing) wouldn't have any effect.
Viton (flouropolymer), polyacrylate, silicone, or maybe nylon are used for valve stem seals. Oil pan gaskets are silicone usually.
I don't think High Mileage really does much any more. Let the oil specs any oil meets tell you how well it will perform.
https://www.youtube.com/watch?v=m7F9AwUUJVE&vl=en is where they go through some marketing ideas they had back in the 90's, for older cars back then.
From the 27.00 point to about 29:10 in https://www.youtube.com/watch?v=FXqkOZAkXZw a Vavloline engineer mentions
that Valvoline High Mileage oil has extra seal conditioners (the main difference) but it also has a small amount of ashless anti-wear compounds, which I think is meaningless since all synthetic oils that pass dexos1 or VW 508 for example have good anti-wear performance already. She also says there are more dispersants to prevent deposits, but again, WPD limits are dictated by dexos1 or other high syn oil specs already.
I have used both.
I find less oil loss with the HM.
Don,t know if it leaks less or evaporates less or both.
Yes I had a need when Pennzoil 5W-20 cost me $4 and change a Jug I figured I needed it. Its in the Corolla now and its seems to be working just fine. 1000 miles so far and the oil level on the dipstick hasn't budged.
- not every car with an oil leak was made yesterday
- are you sure plasticizers don't work on synthetic rubbers like silicone??.. because my bottle of 303 Aerospace Conditioner says it does, weird?
- many aftermarket seals/o rings are nitrile/buna rubber
IMO valvoline should go the "all mileage route" with their maxlife synblend and full synthetic maxlife.
Use "with maxlife technology" and keep the iconic red jug and silver jugs with red trim.
Simple product line with an iconic valvoline branding.
Mobil 1 should have done the same thing...
Originally Posted by bullwinkle
MaxLife full synthetic has routinely been the best (according to UOAs here) oil that Valvoline makes, and it won't hurt a non-high mileage engine to use it.
Agreed. I don't use it for the the "proposed high mileage benefits", I like it because of the add pack it has. I have a couple of vehicles that I've used it in since new. VMLFS costs exactly the same as VFS at my local WM, so why not pay the same for the better add pack and perhaps merely possible other benefits...
Once again you put out false info. Why?
What did he say that is false?
That's why I have it in both of my vehicles right now, plus I've always trusted Valvoline.
When I bought the motor oil Valvoline was on sale and the synthetic with Maxlife technology was the same price as regular synthetic. So this is what I have. It's a fine PCMO IMHO.
