Rear Struts Recommendations
by willbur - 01/17/20 07:46 AM
Critical Windows 10 Update
by doitmyself - 01/17/20 07:38 AM
Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
71 registered members (AndyB, 4WD, asleepz, atikovi, 2015_PSD, 6 invisible), 1,719 guests, and 17 spiders.
Topics300,216
Posts5,171,093
Members70,452
Most Online3,728
Jan 11th, 2020
13 chevy equinox I4 engine oil in filter box #5290483 12/10/19 02:04 PM
F
Fitter30 Offline OP
F
Knowing that this engine 2.4 has a reputation of clogged or freezing up pcv system and blowing rear main seal. C FM makes a breather with a check valve to relieve crankcase pressure. Finding oil (ounce or two) in filter box and corrugated tube to intake box starting to worry about this problem.
https://www.c-f-m.com/performancepa...quinox-GMC-Terrain-2-4L-Ecotec-p6443.htm
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5290502 12/10/19 02:21 PM
E
eljefino Offline
E
I'd say go for it.
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5290563 12/10/19 03:45 PM
I
Imp4 Offline
I
$80 seems like a lot.
Why not just keep the PCV and associated hoses/tubing clean and clear???
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 13 chevy equinox I4 engine oil in filter box [Re: Imp4] #5290601 12/10/19 04:23 PM
M
MrHorspwer Offline
M
The PCV is a fixed orifice in the cylinder head. It is inaccessible unless you remove the intake manifold.
Not that the idea is bad, it's just difficult to do on a regular basis.
Re: 13 chevy equinox I4 engine oil in filter box [Re: MrHorspwer] #5290641 12/10/19 04:59 PM
R
ragtoplvr Online Content
Online Content
R
I think I would add a supplemental path. The OE design is cheap cheap cheap, and not terribly reliable. The part shown with the filter element is one of those kind of solutions.
Or you could drill a hole in the valve cover, fit a grommet and put in another PVC, to the intake. However that could mess with the OE computer.
In any case, it is a gm mistake.
Rod
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5290654 12/10/19 05:13 PM
B
bruckus Offline
B
Another option is a vented AC Delco cap which is the vented version of the OEM cap. P/N FC219
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5290687 12/10/19 05:42 PM
super20dan Offline
this total pos engine has more problems than just the pcv system
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: 13 chevy equinox I4 engine oil in filter box [Re: super20dan] #5291142 12/11/19 07:44 AM
M
MarkM66 Offline
M
What other problems are associated with this engine?
My parents have this vehicle. So I can give a heads up.
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5291570 12/11/19 01:31 PM
F
Fitter30 Offline OP
F
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5291784 12/11/19 06:52 PM
super20dan Offline
there is also,the defective timing chain issue. my neighbor who is extremely stupid. bought a new equinox in 2011 and it was plagued by all the 2.4 issues. also he was too lazy and stupid to ever check the oil EVER between changes. dispite knowing it was consuming oil at a rapid rate. it got run low on oil so often its amazing it never seized, I told him about the wide spread internet post about this was happening to almost all the 2.4,s and the dealer was doing oil comsumption tests and replacing pistions and rings for free. well he was too stupid to take my advice and one day his wife came to my door saying the car was making noise and the oil light was on. I checked oil-4 quarts low.. he traded the car in and took a bath.
99 silverado 5.3
2003 tundra v6
2003 kia sorento
Re: 13 chevy equinox I4 engine oil in filter box [Re: Fitter30] #5294450 12/14/19 04:03 PM
F
Fitter30 Offline OP
F
bruckus order the new cap thanks for the part number. Going to take the in after the holidays for the oil test.
