Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
P38 Lightning
by Kamele0N - 01/16/20 03:01 PM
Why does oil in the spark plug hole cause misfires?
by berniedd - 01/16/20 02:27 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
68 registered members (AndyB, 4WD, 2015_PSD, adams355, alchargo, alarmguy, 5 invisible), 1,563 guests, and 14 spiders.
Topics300,215
Posts5,171,082
Members70,452
Most Online3,728
Jan 11th, 2020
FI cleaners ruin injectors? #5290413 12/10/19 12:54 PM
R
Redright9 Offline OP
R
Hello, I have had a couple people tell me recently that they used too much fuel injector cleaner and it damaged the injectors. Anyone hear of this?
Re: FI cleaners ruin injectors? [Re: Redright9] #5290419 12/10/19 12:58 PM
gathermewool Offline
more info, please....
e.g., damaged how? Symptoms? Who told them and how did that person know?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: FI cleaners ruin injectors? [Re: Redright9] #5290433 12/10/19 01:09 PM
Dave9 Offline
More likely, they had fuel injector problems and those didn't go away by (an attempted fix-in-a-bottle) cleaning.
You should get more specific details from those who stated it.
Re: FI cleaners ruin injectors? [Re: Redright9] #5290459 12/10/19 01:40 PM
Yah-Tah-Hey Offline
Nonsense
Re: FI cleaners ruin injectors? [Re: Redright9] #5290469 12/10/19 01:53 PM
B
BMWTurboDzl Offline
B
I've only read of one instance where a leaky injector was attributed to over zealous use of a cleaner (SL-1).
Trav is probably the most qualified to answer this question.
435i
Re: FI cleaners ruin injectors? [Re: Redright9] #5290480 12/10/19 02:01 PM
R
Rand Offline
R
"A couple people?"
I can barely name a couple people who HAD fuel injector problems... let alone several that attribute it to fuel injector cleaner.
Re: FI cleaners ruin injectors? [Re: Redright9] #5290523 12/10/19 02:50 PM
A
AC1DD Offline
A
Highly unlikely if it's the bottle in tank type, especially if you follow the directions, even if you don't that stuff is very safe for any modern (past 30 years) rubber and plastics.
Re: FI cleaners ruin injectors? [Re: Redright9] #5290604 12/10/19 04:24 PM
R
R
The most recent person had a Toyota truck and a check engine light came on. Supposedly the shop stated the injectors shorted out because of too much cleaner. The other two people (this was a while ago) were no starts/not getting fuel... All people said they use a bottle almost every tank. I agree and dont feel injectors really are something that fail that often, and the off the shelf cleaners are not aggressive enough to damage an injector. But just thought I would see if anyone else heard of this.
Re: FI cleaners ruin injectors? [Re: Yah-Tah-Hey] #5290610 12/10/19 04:30 PM
Cujet Offline
Originally Posted by Yah-Tah-Hey
Nonsense
Quoted for truth
Re: FI cleaners ruin injectors? [Re: Redright9] #5290631 12/10/19 04:50 PM
Z
zzyzzx Online Sleepy
Online Sleepy
Z
[Linked Image from i.ytimg.com]
Re: FI cleaners ruin injectors? [Re: Redright9] #5290632 12/10/19 04:51 PM
javacontour Offline
I think I'd ask the show to explain how something in the fuel would cause a short in the electrical part of the injector.
Or maybe it's time for that person to seek out another shop.
Maybe Trav could explain how this could or could not be the case.
network down, IP packets delivered via UPS -BOFH
Re: FI cleaners ruin injectors? [Re: zzyzzx] #5290635 12/10/19 04:51 PM
javacontour Offline
How did you get a picture of me when I read that sentence?
Re: FI cleaners ruin injectors? [Re: Redright9] #5290675 12/10/19 05:32 PM
T
Trav Offline
T
The injectors are not shorting out inside from using cleaners, alcohol or anything else. If the person ran a full bottle every tank the concentration keeps getting greater with every tank and at some point the mix doesn't like to light (if its PEA based cleaner), solvent based types like Berrymans, Kreen, etc are not as effected.
SI-1 for example works fine with one full bottle the first use a full bottle every 3-5K or 2-3oz or so every full tank.
Re: FI cleaners ruin injectors? [Re: Redright9] #5290705 12/10/19 06:03 PM
dave1251 Offline
No it didn't happen.
don't use.
Re: FI cleaners ruin injectors? [Re: Redright9] #5290753 12/10/19 07:03 PM
MolaKule Offline
Global Moderator
Global Moderator
Trav may better explain than I but if this electronically controlled fuel injector is of typical construction, one has to ask himself how would PEA or fuel for that matter could ever come in contact with the coils carrying the current pulses?
See "Animated cut through diagram of a typical fuel injector. Click to see animation."
here: Fuel Injector animation
Organic Amines are chemically BASIC and not acidic: Amines
Now acids of sulfur and phosphorus may attack copper but generally amines do not.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
