Originally Posted by Jimmy_Russells
Originally Posted by nicholas
My point is that 87 will do zero engine damage for an engine designed to use it - - - Audi's, BMW's, ect.... all recommend 91 octane, they are tuned to use this.
The point that 87 will damage a turbo direct injected engine holds no water, and makes zero sense- - - - even the article someone posted has zero to do with 87 octane damage.
91 will make it easier for manufacturers to hit the mpg targets governments are posting - - thats it thats all.......
With all due respect, this is false. If you hear preignition, it's already too late. It's already had preignition evens that are not audible. Knock sensor input to ECU takes time to process, even if milliseconds. Adjusting ignition timing takes time too. Add a combustion chamber volume lessening layer of carbon, lean fuel mixtures and superheated carbon particles and 87 octane won't do the job anymore. Engineering has its limits and these limits are pushed every model year.
If you have a DI turbo car, run higher octane fuel or you (or the next owner) will experience some form of consequence, whether it's lower power output, non optimal fuel mileage, or something more impactful such as catastrophic engine failure.
You may choose to adjust your rose colored glasses as time goes on or adapt and inform yourself as technology changes.
You have no clue what you are talking about -- - - - - Engine's today adjust timing in milliseconds in every aspect of the combustion cycle.
You are simply incorrect - - no rose coloured glasses here.
87 and a turbo engine "designed" to use it - - - - - for the love of everything - I am not talking about euro engines - - - is fine. It makes zero sense that an engine that was programed to use 87 would ping under any circumstance........................zero sense.
Carbon in the cylinders or "hot spots" - - - 91 is not going to prevent this of detonation.
He was a tech for Hyundai for years
I have had many discussions with "techs" over the years, only a small handful really knew what they were talking about.
Just because someone is or was a tech really holds zero for me.....now if you said he worked for shell then that might be different.
