Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
P38 Lightning
by Kamele0N - 01/16/20 03:01 PM
Why does oil in the spark plug hole cause misfires?
by berniedd - 01/16/20 02:27 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
73 registered members (AndyB, 2015_PSD, adams355, alchargo, alarmguy, 4WD, 5 invisible), 1,427 guests, and 16 spiders.
Topics300,215
Posts5,171,076
Members70,452
Most Online3,728
Jan 11th, 2020
The forgotten Bolens 1253 #5290348 12/10/19 11:49 AM
L
Lubener Offline OP
L
[Linked Image]
My forgotten Bolens which my grandmother purchased in 1972, sat in a barn, slowly sinking in the ground for nearly 15 years after a screw loosened from the carburator throttle blade and beat the piston into submission on the iron Tecumseh engine. About four years ago I decided to bring it back to life. The cylinder had prior been bored .020 over and luckily it was in good shape. I had to replace the (piston, rings .020 over), rod, head and gaskets along with a couple used tires. The valves survived but had the exhaust valve guide replaced at a machine shop because it was sloppy.
I have the mower, tiller and dirt plow attachments but just do garden tilling with it now. When I was cleaning out the barn, I just couldn't scrap my Grandmother's Bolens and made a good winter project back in 2015. It will always be "Grandma's Bolens".
The "thinking" man's friend.
Re: The forgotten Bolens 1253 [Re: Lubener] #5290353 12/10/19 11:54 AM
B
Brian123 Offline
B
Awesome for what you did, good luck going forward.
Re: The forgotten Bolens 1253 [Re: Lubener] #5290397 12/10/19 12:34 PM
B
Bebop367 Offline
B
Neighbor has old Bolens Tractor from 1970's.
It little larger and still going.....
Got to be tough machines
Re: The forgotten Bolens 1253 [Re: Lubener] #5290422 12/10/19 01:00 PM
F
FT92 Offline
F
nice to see it up and running again...just can't beat that old iron...I have a large frame 1886 (1972 vintage ) , just push snow or dirt/gravel with it now but still runs and does what I need it to do,,,
Re: The forgotten Bolens 1253 [Re: Lubener] #5290704 12/10/19 06:01 PM
J
joekingcorvette Offline
J
That looks like a very heavy duty rig. Nice to see you gave it another chance at survival.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: The forgotten Bolens 1253 [Re: Lubener] #5290712 12/10/19 06:07 PM
M
maxdustington Offline
M
Accoutrements and intact original paint? You had to! Not bad for fifteen years sitting in the mud, that's usually a death sentence.
There's some nice old tractors on this board. That Cub Cadet that was posted recently was MINT!
99 Toyota Tercel CE 5EFE/C151
Re: The forgotten Bolens 1253 [Re: Lubener] #5290785 12/10/19 07:40 PM
T
TriMoto Offline
T
They are great tractors.
Re: The forgotten Bolens 1253 [Re: Lubener] #5291116 12/11/19 06:58 AM
M
motor_oil_madman Offline
M
Interesting failure. How often does that happen?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: The forgotten Bolens 1253 [Re: motor_oil_madman] #5291150 12/11/19 07:49 AM
J
jeepman3071 Online Content
Online Content
J
I've seen it a total of 3 times over 14 years of working on stuff. 1 Briggs and 2 Kohlers. Usually the screws for the throttle plate have a dab of blue loctite on them to keep them from coming out, but if someone removes the screws for some reason or the factory forgets to apply the loctite they can loosen and get sucked in through the intake. It usually damages the piston and scratches up the cylinder walls pretty good. I had one where I removed the cylinder head and the screw was still stuck in the piston. That one still ran but lacked power and smoked like a train.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: The forgotten Bolens 1253 [Re: jeepman3071] #5291634 12/11/19 03:06 PM
L
Lubener Offline OP
L
Actually, the carb was never touched other than removing it years ago when the engine was originally rebuilt about 25 years ago.
