Rear Struts Recommendations
by willbur - 01/17/20 07:46 AM
Critical Windows 10 Update
by doitmyself - 01/17/20 07:38 AM
Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
88 registered members (4WD, AndyB, andyd, atikovi, asleepz, 6 invisible), 1,766 guests, and 23 spiders.
Topics300,217
Posts5,171,107
Members70,452
Most Online3,728
Jan 11th, 2020
Valvoline High Mileage vs Valvoline Full Synthetic? #5290283 12/10/19 10:33 AM
B
Bettez88 Offline OP
B
Why would one go for the maxlife vs the regular full synthetic oil? Is there really a need for high mileage synthetic?
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: Bettez88] #5290286 12/10/19 10:38 AM
F
ford46guy Offline
F
Marketing 101. People like to see different things.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: ford46guy] #5290308 12/10/19 11:09 AM
B
Bettez88 Offline OP
B
So there is really no point in using high mileage synthetic then is what you’re saying
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: Bettez88] #5290330 12/10/19 11:30 AM
F
ford46guy Offline
F
Can you really prove a concrete benefit(not really). There may be more or less of an additive, but its mostly marketing. No manufacturer is suggesting it, and some have extended warranties to 120K.
So it is like the engine will go to 350K with the HM and 300K with the synthetic? Even they can't make that claim.
One can argue it swells seals a bit but eventually they fail harder (may or may not be true).
No different (to me) than saying a laundry detergent gets clothes 49% brighter than the competition.
It is more a feel good thing.
Re: Valvoline [Re: Bettez88] #5290331 12/10/19 11:30 AM
M
Mad_Hatter Offline
M
Greater detergency/dispersants
Thicker oil to combat blow by
More AW additives
More seal conditioners
Higher TBN, Pennzoil for example has a +9 tbn
Esters for cleaning things like the rings and valve guides
Low(er) volatility to combat consumption
Not every HiMi formula fits this bill so you have to check out the PDS.
Re: Valvoline [Re: Bettez88] #5290332 12/10/19 11:31 AM
P
paoester Offline
P
Seals are usually silicone rubber these days, about widespread post-2002 or so, meaning any extra seal conditioners (high mileage oil's main thing) wouldn't have any effect.
Viton (flouropolymer), polyacrylate, silicone, or maybe nylon are used for valve stem seals. Oil pan gaskets are silicone usually.
I don't think High Mileage really does much any more. Let the oil specs any oil meets tell you how well it will perform.
https://www.youtube.com/watch?v=m7F9AwUUJVE&vl=en is where they go through some marketing ideas they had back in the 90's, for older cars back then.
From the 27.00 point to about 29:10 in https://www.youtube.com/watch?v=FXqkOZAkXZw a Vavloline engineer mentions
that Valvoline High Mileage oil has extra seal conditioners (the main difference) but it also has a small amount of ashless anti-wear compounds, which I think is meaningless since all synthetic oils that pass dexos1 or VW 508 for example have good anti-wear performance already. She also says there are more dispersants to prevent deposits, but again, WPD limits are dictated by dexos1 or other high syn oil specs already.
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: Bettez88] #5290334 12/10/19 11:31 AM
B
bullwinkle Online Confused
Online Confused
B
MaxLife full synthetic has routinely been the best (according to UOAs here) oil that Valvoline makes, and it won’t hurt a non-high mileage engine to use it.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: Bettez88] #5290337 12/10/19 11:37 AM
T
tblt44 Offline
T
I have used both.
I find less oil loss with the HM.
Don,t know if it leaks less or evaporates less or both.
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: Bettez88] #5290400 12/10/19 12:37 PM
JohnnyJohnson Offline
Yes I had a need when Pennzoil 5W-20 cost me $4 and change a Jug I figured I needed it. Its in the Corolla now and its seems to be working just fine. 1000 miles so far and the oil level on the dipstick hasn't budged.
2004 Corolla 138272
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: paoester] #5290405 12/10/19 12:44 PM
M
Mad_Hatter Offline
M
- not every car with an oil leak was made yesterday
- are you sure plasticizers don't work on synthetic rubbers like silicone??.. because my bottle of 303 Aerospace Conditioner says it does, weird?
- many aftermarket seals/o rings are nitrile/buna rubber
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: Bettez88] #5290450 12/10/19 01:25 PM
B
BLND1 Offline
B
IMO valvoline should go the “all mileage route” with their maxlife synblend and full synthetic maxlife.
Use “with maxlife technology” and keep the iconic red jug and silver jugs with red trim.
Simple product line with an iconic valvoline branding.
Mobil 1 should have done the same thing...
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: bullwinkle] #5290667 12/10/19 05:27 PM
E
ejes Offline
E
Agreed. I don't use it for the the "proposed high mileage benefits", I like it because of the add pack it has. I have a couple of vehicles that I've used it in since new. VMLFS costs exactly the same as VFS at my local WM, so why not pay the same for the better add pack and perhaps merely possible other benefits...
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: paoester] #5291101 12/11/19 06:32 AM
dave1251 Offline
Once again you put out false info. Why?
don't use.
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: dave1251] #5291688 12/11/19 04:21 PM
Z
zrxkawboy Offline
Z
What did he say that is false?
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Valvoline High Mileage vs Valvoline Full Synthetic? [Re: ejes] #5291933 12/11/19 09:44 PM
N
Noshow13 Offline
N
That’s why I have it in both of my vehicles right now, plus I’ve always trusted Valvoline.
2005 Chevrolet Silverado 5.3L Z71
