ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
P38 Lightning
by Kamele0N - 01/16/20 03:01 PM
Why does oil in the spark plug hole cause misfires?
by berniedd - 01/16/20 02:27 PM
Broken mounting ears for AC Compressor Pics.
by tig1 - 01/16/20 01:48 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
66 registered members (4WD, 2015_PSD, Aero540T, aircooled, Astro14, 67ZL1, 7 invisible), 971 guests, and 16 spiders.
Topics300,214
Posts5,171,041
Members70,452
Most Online3,728
Jan 11th, 2020
SN vs SN+ #5289934 12/09/19 11:02 PM
N
natas Offline OP
N
I was wondering if anyone could help me understand any real benefit using the new SN+ oils, as opposed to the SN oils in a regular non turbo-charged, non TGDI automobile? Looking at various VOAs, generally speaking, the calcium numbers have gone way down, usually around 500-600ppm, while magnesium levels have gone way up, giving a rough Ca/Mg total of around 1900ppm-2000ppm. For example if an old SN oil had Ca of around 1900-2100, it will now be around 1500. And Mg will be around 400-500. I understand how this may be good for the whole LSPI thing, but what about in a regular (older) car? In addition, it was my <limited> understanding that Magnesium is a more abrasive detergent than Calcium, so I was just wondering how better/worse/the same it would be vs. its replaced SN counterpart--mainly for engine protection/wear. If anyone can educate me on this, I would be most appreciative. I know the new standards supersede the previous ones, etc.etc., but when seeing the numbers drop, and others add up to address a newer type of engine, while the API protection parameters might be "sufficient", I'm just wondering if ALL potential "good-aspects" of the SN+ will be applied to older car engines (i.e. Manifold Fuel Injection, Fuel Rail, or even Carbureted). Thank you.
Re: SN vs SN+ [Re: natas] #5289936 12/09/19 11:06 PM
demarpaint Offline
I doubt there's any benefit at all for the engine type you mentioned.
God Bless Our Troops
Re: SN vs SN+ [Re: demarpaint] #5289943 12/09/19 11:23 PM
N
natas Offline OP
N
I think you may be right--and correct me if I'm wrong, but won't SN oil will be phased out (i.e. no longer available as stock dwindles) off the shelf--or will be be continued to be sold/produced alongside SN+ oil?
Re: SN vs SN+ [Re: natas] #5289954 12/09/19 11:47 PM
Doublehaul Offline
IIRC the only difference is low speed pre ignition
If you want advantages in non tgdi or gdi or frankly with either of the following dexos 1 gen 2 is what your after
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: SN vs SN+ [Re: Doublehaul] #5289959 12/10/19 12:05 AM
N
natas Offline OP
N
Just everyday cars, 2000-2010s toyotas, 2000s chryslers, 90s GMs, etc. Nothing too new.
Re: SN vs SN+ [Re: natas] #5289963 12/10/19 12:11 AM
dave1251 Offline
I would not worry about the detergents and wear. The wear requirements did not lessen.
don't use.
Re: SN vs SN+ [Re: natas] #5289974 12/10/19 12:41 AM
M
Mad_Hatter Offline
M
SN+ was introduced to address LSPI specifically. You have a NA engine so API SN/GF5 is more than sufficient but if timing chain wear is of particular concern of yours, Dexos 1 Gen 2 would serve you well.
Fwiw, the upcoming release of GF6 will address TC and LSPI concerns IIRC. (similar to Dexos 1 but the testing is slightly different IIRC)
Good discussion on Mag v. Cal
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2089814#Post2089814
Re: SN vs SN+ [Re: Mad_Hatter] #5289975 12/10/19 12:47 AM
N
natas Offline OP
N
Yes...but *will* SN oil continue to be available? Or will all the major brands replace all their SN products (Chevron, Valvoline,Pennzoil, etc. etc.) with SN+. i.e., only SN+ will be available on the shelf since it "supersedes all previous API categories)?
In other words, when I goto Walmart, will I soon (if not now) *not* be able to get an SN oil from a preferred brand--and only have SN+ to choose from?
Re: SN vs SN+ [Re: natas] #5289982 12/10/19 01:34 AM
Char Baby Online Content
Online Content
[quote: natas] In other words, when I goto Walmart, will I soon (if not now) *not* be able to get an SN oil from a preferred brand--and only have SN+ to choose from?[quote]
I would say yes, that would be my thinking.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: SN vs SN+ [Re: natas] #5289990 12/10/19 03:07 AM
M
Mad_Hatter Offline
M
Well if past is precedence I'd say that SN will eventually fade away from Wally's shelves as more and more new vehicle owners manuals begin to spec API SP/GF-6 and command space on the shelves. If you want/prefer the pre SN+ levels of Cal/Mag you're gonna have to hunt it down. But I *think* low Cal is here to stay since the consensus seems to be it's an antagonist to LSPI events.
Re: SN vs SN+ [Re: natas] #5289993 12/10/19 03:22 AM
I
Imp4 Offline
I
No, SN will not continue to be available. It is currently being replaced by SN+ and that is a good thing.
With the exception of a few very specific circumstances, API oils are backwards compatible. That means that the SN+ oil exceeds the performance requirements of SN oil and the SN+ oil can be used in any situation where SN oil is specified.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: SN vs SN+ [Re: natas] #5290002 12/10/19 03:59 AM
P
paoester Offline
P
SN+ is fine going forward for any engine. It passes the same engine tests as for SN, plus one LSPI test was added. .... We have another year left of it, and then SP (GF6) takes over.
Current dexos1 oil is better than SN or SN+ ratings alone, and combining dexos1 with SP GF6 later on will be a bit better still.
Re: SN vs SN+ [Re: natas] #5290006 12/10/19 04:08 AM
T
Triple_Se7en Offline
T
My oil stash should be gone when GF6 arrives.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: SN vs SN+ [Re: natas] #5290007 12/10/19 04:13 AM
demarpaint Offline
In time SN and SN+ will be gone, replaced GF6, etc. A slow evolution.
Re: SN vs SN+ [Re: demarpaint] #5290011 12/10/19 04:28 AM
T
T
Yep, the guys here that bought (hypothetical) 10 five quart jugs of Gas Truck, to feed their engines for the next several years, will be in Sell-Sell Mode and starving for the first-ever sales on GF6 oils.
