Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
Harry_Seaward, MrH1325, Thetarmac, lbstyling, tanpw
70483 Registered Users
38 registered members (AZjeff, bmod305, blufeb95, 750IX, adams355, 4 invisible), 1,109 guests, and 40 spiders.
Topics300,336
Posts5,173,602
Members70,483
Most Online3,825
Jan 19th, 2020
Using kerosene/ heating oil in a common rail diesel engine #5289766 12/09/19 07:07 PM
Diffinking Offline OP
As above Using kerosene/ heating oil in a common rail diesel engine
Is this possible we have 2 big tanks of kero/heating oil at the yard , now we have off- road bmw x3 using 2.0d m47 engine , that will be drove on private land
Will this vehicle run on kerosene , if so will it need added lubricants to help pump and Injector wear
Appreciate all replys
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5289786 12/09/19 07:29 PM
JohnnyJohnson Offline
It will run if you mix it with diesel that's what they call winter diesel.
2004 Corolla 138348
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5289791 12/09/19 07:34 PM
dbias Offline
I'd not use kerosene at any more than 25% with additional lubrication in a common rail diesel. Common rail diesel operate at very high pressures and the lack of lubrication from the kerosene couldn't be good.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5289792 12/09/19 07:35 PM
Chris142 Offline
I would not do that with a BMW. An old mechanical idi would be a better choice.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5289803 12/09/19 07:48 PM
A
Audios Offline
A
My friend runs heating oil in all of his diesels, they vary from an B5 S4 wagon with a swapped tuned tdi motor, to a 2016 A7 Tdi. He runs 2 stroke as an additive. Like others have said, 25% would be my max and Id definitely want an additive in there as well.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5289860 12/09/19 09:01 PM
Donald Offline
Maybe in your diesel, but not mine. I want super clean diesel with the proper lubricant.
2015 Ford F-250 w/Powerstroke
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5289909 12/09/19 10:02 PM
M
meadows Offline
M
I would make sure the heating oil is ultra low sulfur. The emission control equipment is expensive.Would not run kerosine.
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5290052 12/10/19 06:34 AM
B
BMWTurboDzl Offline
B
Lubricity additive is a must.
435i
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5290068 12/10/19 06:50 AM
Cujet Offline
Jet-A is a kero based product. I tested it's lubricity at about 650 HFRR, which is terrible. The maximum spec (lower is better) for diesel is, I think, 450. Adding Stanadyne lubricity additive did not bring Jet-A into range. But adding 200 to 1 TCW-III along with Stanadyne lubricity additive brought Jet-A to 255, on the HFRR. (High Frequency Reciprocating Rig)
I've used that ratio for 20 years without any issues what so ever. Although I will admit the oil did not always completely burn in some devices (stationary low RPM generators) under low load and left an oily soot in the tailpipe. I bring that up because Catalytic Converters and DPF's may have trouble with higher oil concentrations. I never had any issues with Cat's. Never any issues with EGR or EGR coolers. The Cummins motorhome, Jetta, Mercedes, Dodge truck and other VW's never experienced any troubles of any sort.
Re: Using kerosene/ heating oil in a common rail diesel engine [Re: Diffinking] #5295183 12/15/19 02:34 PM
sdowney717 Offline
Not in any common rail diesel I own. Some people learn the hard way.
