Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Helicopter
by Exhaustgases - 01/28/20 01:25 AM
Shell Helix Ultra 5W-30
by SR5 - 01/28/20 12:30 AM
Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
SandeepG, IslandOil, 01VFR, M10, H20ham
70545 Registered Users
92 registered members (1WildPig, 1978elcamino, 53' Stude, 2strokeNorthstar, 330indy, 14 invisible), 3,324 guests, and 22 spiders.
Topics300,665
Posts5,180,618
Members70,545
Prestone Command in Caterpillar Engine, #5289621 12/09/19 05:01 PM
G
George7941 Offline OP
G
At work we have a Freightliner with a CAT C7 engine and I have been using genuine CAT ELC coolant in it. The coolant is a bit expensive.
I can get the Prestone coolant for about a third of the price of CAT coolant.
https://prestone.com/command/products/heavy-duty-extended-life.php
The Prestone coolants are on sale at Fort Garry Industries
https://www.fortgarryindustries.com/promotion/fgi-on-december-19/
Any downsides to using the Prestone coolant?
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Prestone Command in Caterpillar Engine, [Re: George7941] #5289640 12/09/19 05:22 PM
CDX825 Offline
Its a diesel elc coolant and it meets the cat EC-1 spec. I don't think you will have any issues.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Prestone Command in Caterpillar Engine, [Re: CDX825] #5289765 12/09/19 07:04 PM
G
G
Data sheet for the Prestone coolant https://prestone.com/command/downloads/15-PRES-0279-Combined-Red-Data-Sheet-US_FNL.pdf
They state "meets or exceeds the performance requirements of-------EC1-------". Is this just their opinion or did they actually carry out the tests? I could ask them, they may or may not have a definitive answer.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Prestone Command in Caterpillar Engine, [Re: George7941] #5289807 12/09/19 07:53 PM
Chris142 Offline
If it passes the diesel coolant spec the engine requires it will be fine.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Prestone Command in Caterpillar Engine, [Re: George7941] #5290171 12/10/19 08:23 AM
L
Langanobob Offline
L
George, I have an older Ford Diesel pickup and I also struggle with coolant specs, although on a smaller scale and with my own money. Part of the reason the CAT coolant costs 3 times as much may be due to the CAT name but part of the cost may also be for superior coolant - I don’t know for sure. I believe Caterpillar was involved in the initial research involving Diesel cylinder liner cavitation erosion.
Speaking only for myself, if I was charged with maintaining a truck owned by my employer I would run the CAT coolant. Isn’t the coolant service life something like 750,000 miles? The extra cost of the CAT coolant is completely negligible on a cost per mile basis. The extra money may be literally down the drain or it may be a very good investment in the service life of the engine. We don’t 100% know and it’s not your money you are to some extent gambling with.
I hate to even bring this topic up, but it’s part of the reality we live in. If you use the cheap coolant and something like the water pump should fail for some completely unrelated cause, who is going to have fingers pointed his direction?
Since it is your employers truck and your employers money, barring any completely conclusive facts to the contrary I would use the CAT coolant.
Probably equally important is a proper drain and flush of the old coolant.
Edit: I would ask Caterpillar tech support why their coolant is so bloody expensive and ask them to explain why it is worth the extra money.
Re: Prestone Command in Caterpillar Engine, [Re: Langanobob] #5290519 12/10/19 02:46 PM
G
G
The long service life certainly helps mitigate the initial high cost of the coolant if I could keep the coolant in that long. The rad drain is not user friendly at all, you can sort of stick a hose into a hole and try and direct the flow of coolant into clean jugs but the coolant spills all over the place and a lot of the coolant gets lost. It is a very high mileage engine and the coolant has to be drained every so often, for water pump replacement, stat replacement etc. The current issue is a coolant leak at the air compressor head and the system has to drained before I can address the leak.
One of the reasons for high cost is CAT pushing sale of the 50/50 instead of the concentrate. With the Prestone I can buy the concentrate and use distilled water to get it to 50/50.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Prestone Command in Caterpillar Engine, [Re: George7941] #5290850 12/10/19 08:26 PM
X
xxch4osxx Offline
X
We have used Texaco and Chevron and this Prestone coolant in the Cat C-15 engines at work and never had any issues. Big companies like that aren't going to state it meets spec when it doesn't.
That Fort Garry out in Missisauga is an awesome store to visit, so much cool stuff!
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
