AZjeff
$50 Site Donor 2023
Originally Posted by Chris142
If you pull the pack out a spring shop can replace just that one spring very cheaply.
True but every town doesn't have a spring shop. Used springs from Arizona might be a mile away from breaking from the sounds of it. If you like the truck get some aftermarket springs installed and keep it, this is a known part failure apparently.
