Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
23 registered members (ctechbob, BlueOvalFitter, E365, carlprop, CPA1989, dogememe, 2 invisible), 1,141 guests, and 24 spiders.
Topics300,450
Posts5,176,066
Members70,506
Oil cleaner? #5289398 12/09/19 01:32 PM
Dbow Offline OP
Hello,
I have a 2014 ram 2500 Cummins motor with 120,000 miles. I purchased the truck recently and it had good service records up until about 30k miles ago. I know it was taken good care of before that because of the service records and I assume it was after that but there’s no record to prove my assumption. I am curious about using an oil and fuel cleaner and figured I should turn to the experts.
I have read about a few products and the two I have in mind are products made by Powermaxx called “bluechem Oil System Cleaner” and “bluechem Common-Rail Diesel System Clean & Protect.” Are these products something worth using to help prolong the life of the motor?
I’ve also found some positive things said about Hot shots secret products and they have two products similar to the ones I mentioned above. Would they be a better option to go with?
Thank you,
Dbow
Re: Oil cleaner? [Re: Dbow] #5289414 12/09/19 01:50 PM
Dave9 Offline
I'd start by just changing the oil and doing it again on a shorter OCI, then go back to the regular OCI you intended.
Fuel cleaner, sure you could put some in but it probably won't make much difference unless you have observed problems that suggest clogged fuel injectors.
Re: Oil cleaner? [Re: Dbow] #5289432 12/09/19 02:07 PM
Dbow Offline OP
I changed the oil and and fuel filters the same week I brought it home. So I will follow your advice and change it on a shorter interval this time. You wouldn’t recommend adding an oil system cleaner before this next oil change?
The fuel system doesn’t have any bad symptoms. I guess I was just thinking of adding something as a preventative measure.
Re: Oil cleaner? [Re: Dbow] #5289496 12/09/19 03:15 PM
B
BAJA_05 Offline
B
Welcome to the Forum -- good/knowledgeable advice given here by multiple multiple members.
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Oil cleaner? [Re: Dbow] #5289599 12/09/19 04:39 PM
O
OLEJOE Offline
O
Yeah I would just run a short OCI and if you are concerned about it do a UOA. Use the proper oil, good filters and decent change interval and you shouldn't have any oil related issues. Keep the fuel filters changed as recommended and you shouldn't have issues there either. Has the truck been deleted or still stock?
Jack of All Trades. Master of some.
Re: Oil cleaner? [Re: Dbow] #5289616 12/09/19 04:58 PM
Marco620 Offline
Make sure to get a quality air filter and check/listen for leaks. A quality air filter keeps oil clean.And NO K&N filters please.
15' Civic 1.8 i-vtec 302,000 mi M1 AP 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,Heckler & Koch & SONY Aficionado
Re: Oil cleaner? [Re: Dbow] #5289754 12/09/19 06:56 PM
Dbow Offline OP
Thanks for all the advice so far. Sounds like I’ll just do a oil change earlier than I planned to keep it clean.
I replaced the air filter with a new fleet guard filter at the same time as the oil and fuel filters.
Re: Oil cleaner? [Re: Dbow] #5289801 12/09/19 07:44 PM
Dyusik Offline
Donaldson P551833 - 2 micron fuel (rear)
WIX WF10255NP - 2 micron fuel (engine)
Donaldson DBL7349 - 15 micron oil
Biodiesel for fuel supplement in the summer, Power Service products are Cummins approved, Redline diesel additive seems to be highly regarded. I use it for lube, not cleaning.
If you have the Aisin, the best price on lube I found is on Summit, the Mobil 3309, just have to buy >$50 worth for free shipping.
At 120k, I'd change all lubes, axles, T-case, etc.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k STP SYNHM 10w30, WIX 57047
18 RAM 3500 8k DELO SDE15w40, DBL7349
96 Cherokee
Re: Oil cleaner? [Re: Dbow] #5290087 12/10/19 07:19 AM
B
BoiseRob Offline
B
Welcome... If you do a short cycle OCI, use an inexpensive HDEO like Supertech from Walmart...
2007 Chevrolet Silverado 2500HD LBZ Duramax
2016 Jeep Grand Cherokee Ecodiesel
Re: Oil cleaner? [Re: BoiseRob] #5290101 12/10/19 07:28 AM
dnewton3 Offline
Global Moderator
Global Moderator
Agreed.
And when you're done, go ahead and use the ST for the normal OCIs also. The engine won't know the difference, but your wallet will. Get whatever decent brand name or house brand you can find on sale. The engine isn't nearly as picky and finicky as many would have us believe.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Oil cleaner? [Re: Dbow] #5290861 12/10/19 08:38 PM
N
Newman88 Offline
N
These engine are great, I change both my fuel filters every 20k, oil change every 10k. All I use is Baldwin filter 170k trouble free miles.
The only thing is dont forget to change out the CCV (crank case) filter, and for the life of your injection pump and lift pump clean out the filter and strainer in the sending unit.
My truck came with those stupid cap less fuel filler necks, and I ran it like that for 150k, well all that oily dirt got inside the tank and clogged those suckers up to the point I was getting a low fuel rail pressure code. So make this your priority ASAP if you have one of those cap less craps. (I modified mine by getting the filler neck from an 05 f350 cab chassi truck)
Re: Oil cleaner? [Re: Newman88] #5291550 12/11/19 01:11 PM
Dyusik Offline
https://www.amazon.com/Magnetic-Alu...&hvtargid=pla-450713963249&psc=1
Got this ASAP for mine, now, no worries.
96 Cherokee
Re: Oil cleaner? [Re: Dbow] #5292164 12/12/19 07:51 AM
Dbow Offline OP
I’ve got a fuel cap on mine and replaced the CCV filter while I was doing a little work on the intake. Thanks for all the reminders though.
I have been reading into different oils and I can’t decide what to use on my next oil change after this shorter one. I will be moving north so I like the idea of a synthetic 5w40 oil for the colder starts. There’s a comment above about continuing to use the ST oil because the engine doesn’t know the difference. If I use a ST oil instead of a Schaeffer’s the performance would really be the same?
