Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
powhitehorn, Centripetal, MRLakersLA, elksniserviss_lv, Sukhi
70476 Registered Users
105 registered members (alchargo, agpatel, Aichiguy, 25ring, 53' Stude, 10 invisible), 2,889 guests, and 30 spiders.
Topics300,322
Posts5,173,226
Members70,476
Most Online3,825
Jan 19th, 2020
Current Honda Factory Fill #5289054 12/09/19 04:16 AM
A
asiancivicmaniac Offline OP
A
Recently purchased a 2020 Civic. I remember it used to be said that Honda factory fill was "special" because it had a lot of moly in it because it was either part of the add pack or as a result of the assembly lube at the factory. Is that still the case?
How long should I keep the break-in oil? I did the first oci on my '16 Fiesta ST within the first 900 miles and another one 1000 miles after that. Thought it was excessive at first, but the first UOA I did on it pretty early on showed no remaining break-in wear metals.
I plan on following the OLM after break-in on the Civic.
2002 Nissan Maxima: Napa Syn 5W-30, Proline 14459
2020 Honda Civic Si: Factory Fill, OEM filter
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289059 12/09/19 04:40 AM
T
Triple_Se7en Offline
T
You will get opinions on 1K to 10K OCIs. I'm split in the middle at 5K.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Current Honda Factory Fill [Re: Triple_Se7en] #5289068 12/09/19 05:14 AM
O
OilUzer Offline
O
I like your 5K idea. My car was 10K and in the OM break-in paragraph/page never mentioned any early oil change ... Our other new (2014) car same thing ... change at 6500 or 7500.
I've heard about moly in most if not all Japanese engines and one very experienced master mechanic told me not to drain the factory fill too quickly. Filter will catch the stuff in any. That's why I like the 5K.
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289073 12/09/19 05:34 AM
R
RyanY Offline
R
I dont think it will hurt anything to change oil early/often or to wait until the OLM tells you to change it, as long as you use the correct viscosity. Do which ever makes you feel warm and fuzzy.
I waited for the OLM from day 1 through year 3 on my '12 Odyssey and it runs like new at 105k. Now that i tow with it I do 5k even though it would probably be fine to wait for the OLM.
2007 Cadillac CTS 3.6L >128k miles (Castrol Magnatec 5W-30 + ACDelco PF2129G)
2012 Honda Odyssey EX-L >105k miles (STP (Amalie) 0W20 + ACDelco PF2057)
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289084 12/09/19 06:15 AM
B
Bottom_Feeder Offline
B
Keep it in but upgrade to a higher-efficiency filter if you're really worried about it.
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289085 12/09/19 06:17 AM
E
Eddie Offline
E
Do what HONDA recommends and you will not be wrong. Ed
2014 CX5 Touring 2.5L :-)
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289116 12/09/19 07:07 AM
I
Imp4 Online Content
Online Content
I
Read your owner's manual.
In the past, Honda has had an explicit statement about not changing the oil from the factory fill until the OLM states to do so.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289148 12/09/19 07:50 AM
Bud Offline
Don't know what your 2020 owners manual says, but when I bought my Pilot new the manual said leave the factory oil in until the olm told you to change or one year whichever came first. I would follow the owners manual on a new car, not someone's opinion.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289160 12/09/19 08:09 AM
K
Killer223 Offline
K
just fallow the OLM, it's set very conservative anyhow. my oil in my accord is always in great shape when changed at 20% usually around the 9000 miles mark. Blackstone tells me it's good for another 2500 easy.
i also went to 5/30 over the 0/20.
and i use Supertech synthetic. and mobile 1 filters.
19 accord 6sp 2.0T
04 5.9 cummins
95 12V NV4500.
11 ranger 4.0
18 crf450RX
19 Talon
17 Pioneer 1k.
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289164 12/09/19 08:16 AM
A
ARCOgraphite Offline
A
Not again.! Every Month a thread when should I do the first OCI smile smile smile
Anything under 2K is too early and anything over 5K is too long
Somehere in the middle.
On the short end if you drive less miles/day
on the long end if you drive many miles a day.
Then there is the new
"keep the oil in and change the filter camp with a light topoff"
At least that would prevent the big chunks of casting flash and machining curly-fries from getting let loose during a filter bypass waashout event.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289190 12/09/19 08:51 AM
E
Excel Offline
E
The last honda engine I did own
a 2014 4cyl,I sent the oil in for evaluation and it was showing high aluminum
which means it was eating itself so I sold it
2015 Ford F150
2015 Ford Mustang GT,Whipple powered
2017 Yamaha FZ09
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289213 12/09/19 09:16 AM
Danh Offline
Honda’s factory fill is ordinary, but molybdenum is used in assembly lines and washes into the oil. Honda seems to believe this is helpful for a good break-in because the molybdenum keeps hot spots from forming on new cylinder walls, coking oil and preventing a good seal from forming.
So that’s the case for a long first interval. On the other hand, if you look at Civic forums or around here, you’ll find the Honda 1.5T engine is one of the worst for fuel dilution of engine oil. Admittedly, we don’t know how if this is truly harmful, but it’s at least an argument for a shorter oil change interval.
For my last new Honda engine, I ran the factory fill to about 5k. The replacement oil was Idemitsu with Moly, which seemed to provide some of the break-in benefits Honda was looking for. After that, I switched to Mobil1.
Before you take Honda’s Maintenance Minder as gospel, I’d suggest a UOA from a lab like Oil Analyzers that does a good job with fuel dilution. This should tell you whether your particular engine and driving style make long intervals appropriate.
Re: Current Honda Factory Fill [Re: Excel] #5289216 12/09/19 09:19 AM
P
parshisa Offline
P
How high was aluminum that you had to sell the car?
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289217 12/09/19 09:23 AM
P
paoester Offline
P
Originally Posted by mightymousetech
I am a dealer tech (20 years with Acura/Honda) every couple years we get another service bulletin from Engineering stating that doing the first oil change early can damage the engine, and we are NOT to change the factory fill early. The factory fill oil is not the issue, it is the high moly assembly lube used they want retained in the oil. Doing the first oil change early can cause hot spots to form in the engine.
If you do change it early, put in Mazda dealership oil with high moly 0w20, or Zepro high-moly 0w20 from Amazon.
Fram Ultra oil filters filter better than anything else, always good too.
Re: Current Honda Factory Fill [Re: asiancivicmaniac] #5289218 12/09/19 09:24 AM
P
parshisa Offline
P
My 2017 Civic hatch had it’s first oil change at around 4,500mi. Reason for that was rising oil level on the dipstick. I’ve done UOA on factory fill and sure enough it showed elevated wear numbers (which is expected), as well as super low viscosity 5.8cst or so. Never had oil level issues since. Engine consumes no detectable amount of oil. Btw, OLM was reading 60% left when i changed factory fill - no way i’d drive 10k+ on the oil that is thin as ATF. With all of the above - change it anytime, no harm at all
