Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
powhitehorn, Centripetal, MRLakersLA, elksniserviss_lv, Sukhi
70476 Registered Users
101 registered members (angeloc, AC1DD, 55hambone, 928, ammolab, Aero540T, 8 invisible), 3,019 guests, and 20 spiders.
Topics300,323
Posts5,173,288
Members70,476
Most Online3,825
Jan 19th, 2020
Page 1 of 3 1 2 3
90 350 intake gaskets and sealant #5288950 12/08/19 10:01 PM
P10crew Online Content OP
OP Online Content
I’m going to finally tear into my 90 raydo to replace intake gasket set. Has had a very slow coolant leaking onto the top of the intake.
Questions
Is Felpro intake set my best choice?
What type sealer should I use ?
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288963 12/08/19 10:19 PM
clinebarger Offline
The Fel-Pro set is really good. I like Hylomar M or Blue for around the coolant ports & Permatex Ultra Grey for the front & back sealing on the intake.
Be prepared for the old gaskets to be hard as a rock & stuck really good to the heads if original!!!
2001 Chevy Camaro L92/4L80E
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288967 12/08/19 10:24 PM
OP Online Content
Ok thanks!
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288972 12/08/19 10:38 PM
OP Online Content
Looking like I may have trouble finding it locally. Quick search shows maybe our Harley shop has it.
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288974 12/08/19 10:41 PM
Chris142 Offline
Raydo?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288975 12/08/19 10:48 PM
clinebarger Offline
Permatex Aviation Form-A-Gasket also works well.
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288980 12/08/19 10:58 PM
OP Online Content
Chris Silverado
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288981 12/08/19 11:00 PM
OP Online Content
Forma gasket is what I normally use but I am ordering a tube of m from Walmart tonight.
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5288990 12/08/19 11:25 PM
OP Online Content
Ooo not paying $32 on Walmart. Any one know of a chain that may have it ?
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5289120 12/09/19 07:13 AM
T
Trav Offline
T
Hylomar M 1.35oz
Hylomar M 2.7oz
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5289128 12/09/19 07:24 AM
N
nwjones18 Offline
N
I used the Felpro set with the metal core when I did my 4.3. They seemed to have the best reviews at the time and I haven't had any problems since.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5289275 12/09/19 10:26 AM
OP Online Content
Thanks for the info fellas.
Sheesh hylomar is tough to find. 6 parts houses, 2 bike shops and granger. Gave up and ordered from amazon. It ships by seller so that is always slow.
Got enough to last a while though.
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5289826 12/09/19 08:21 PM
clinebarger Offline
I get it from a industrial supply house in Dallas, Far to many use RTV for everything so demand isn't real high for premium non-setting joint compounds.
If I ever find the person that came up with putting RTV on O-rings......I'll kill 'em!!!!
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5289842 12/09/19 08:45 PM
OP Online Content
Yeah I hear you on the orings.
I noticed that you don’t really recommend hylomar for oil. I have been using right stuff for areas with oil . Have you had bad luck with hylomar and oil?
Re: 90 350 intake gaskets and sealant [Re: P10crew] #5289862 12/09/19 09:02 PM
cronk Offline
I use felpro gaskets and permatex "The Right Stuff" on the front and back if the valley.
It comes in a pressurized can like the cheese spread. Goes on easy and havent had any leaks in the 6 or 7 GM intakes I have done over the past several years.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Page 1 of 3 1 2 3
