Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
powhitehorn, Centripetal, MRLakersLA, elksniserviss_lv, Sukhi
70476 Registered Users
105 registered members (alchargo, agpatel, Aichiguy, 25ring, 53' Stude, 10 invisible), 2,889 guests, and 30 spiders.
Topics300,322
Posts5,173,226
Members70,476
Most Online3,825
Jan 19th, 2020
Reman steering rack 09 CRV #5288925 12/08/19 09:24 PM
Chester11 Offline OP
All:
I think I know the answer but is there a decent reman option?
I can’t see spending 1k on a new Honda part. Even the reman Honda options are expensive and don’t include tie rods.
Should I look at Napa or is that a lost cause as well?
I have a small leak at the boot and air seems to be reaching the reservoir. (Even after replacing the hi/low gaskets and even the pump).
Thanks
Re: Reman steering rack 09 CRV [Re: Chester11] #5288927 12/08/19 09:26 PM
R
rubberchicken Offline
R
Air reaching the reservoir - I recall there were some o-rings that frequently failed, causing noise and air leaks. Has you looked at the o-rings yet ?
Re: Reman steering rack 09 CRV [Re: Chester11] #5288953 12/08/19 10:06 PM
cwilliamsws6 Offline
I have a 2007 Honda CR-V (same gen as your 09) and got the rack replaced last year after an accident. My mechanic used a Napa unit, zero issues or complaints. I think you'll be fine going that route.
Only power steering issue I have had was a leaky return line but that's my own fault (long story short my return line came unsecured from it's clips and my axle rubbed a hole into it lol)
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: Reman steering rack 09 CRV [Re: Chester11] #5289117 12/09/19 07:08 AM
T
Trav Offline
T
Jorgen Automotive aka JAC Rack is your best bet for a reman, these are the best I have used (I use a lot of them), zero failures. Napa are Cardone and scrap metal.
https://www.jorgenauto.com/rack-pinion/honda.html
Re: Reman steering rack 09 CRV [Re: Chester11] #5289244 12/09/19 09:52 AM
awesome...thanks Trav...I'll give them a call.
The leak is not bad yet - so I may put this off until spring.
Re: Reman steering rack 09 CRV [Re: Chester11] #5289576 12/09/19 04:22 PM
5
50jeffrey Offline
5
Try rackdoctor.net
Re: Reman steering rack 09 CRV [Re: Chester11] #5289638 12/09/19 05:20 PM
T
Trav Offline
T
I have done quite a few on Odyssey vans using JAC, they send you all the O rings and bits you need plus a return shipping label for the old one.
They are a small family business who takes care and pride in their work, the racks are always centered and adjusted properly and work perfectly.
I have had them build some real obsolete off the wall stuff no one else could do without a core (JAC found a good clean one, it took a while but they got one), it came out perfect.
