Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
109 registered members (2011335d, aquariuscsm, 928, Alfred_B, 1978elcamino, 14 invisible), 3,866 guests, and 25 spiders.
Topics300,352
Posts5,173,979
Members70,491
Quick Strut Advice #5288610 12/08/19 02:24 PM
coopns Offline OP
2004 Camry
Car was inspected and mechanic said needs struts after I mentioned hearing bumping noise in rear. Says he sees it a lot in those and
considering age of vehicle. Recommended the quick strut. Local guy, wasn't trying to sell me.
I want to get another 4 years out of it (kids rig).
Any brand recommendations and are they difficult for the avg diy'er? (I think that is me...)
Coop
Re: Quick Strut Advice [Re: coopns] #5288621 12/08/19 02:29 PM
I
Imp4 Offline
I
I've been very happy with KYBs from rockauto.
Right now they're running about $120 a piece for your application.
If you can wait, they usually go on rebate in the spring.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Quick Strut Advice [Re: coopns] #5288624 12/08/19 02:30 PM
Saabist Offline
For what it's worth, Scotty Kilmer gives thumbs down:
https://www.youtube.com/watch?v=a3bncShvmHU
Re: Quick Strut Advice [Re: coopns] #5288634 12/08/19 02:39 PM
E
eljefino Offline
E
The rear struts are the worst-- you've gotta pull that side bolster to the seat then there's limited room between the strut's upper nuts and the top of the package shelf. Pass-through sockets or ratcheting wrenches help a lot. The big fasteners to the knuckle go faster with air tools but you could do it with breaker bars or whatever medieval stuff you've got.
Some, not all, struts have elongated bolt holes at the knuckle end. Buy these and you'll need an alignment.
Am sure there are youtube videos for this.
In this app I can't imagine quick struts being that awful.
Re: Quick Strut Advice [Re: coopns] #5288647 12/08/19 02:50 PM
The Critic Online Crying
Online Crying
I installed KYB quick struts on this application several years ago and they are holding up fine AFAIK. The only reason I did it was because there were concerns about spring saggage.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Quick Strut Advice [Re: Saabist] #5288665 12/08/19 03:14 PM
I
Imp4 Offline
I
Feels good to disagree with Scotty sometimes...
Re: Quick Strut Advice [Re: coopns] #5288675 12/08/19 03:28 PM
Z
zzyzzx Offline
Z
Used Monroe quick struts on a 2000 Camry, and so far, so good. Have around 50K miles on them.
With any quick struts, check the top nut torque on installation.
Re: Quick Strut Advice [Re: Imp4] #5288702 12/08/19 04:06 PM
W
Wolf359 Offline
W
Well not going to watch another Scotty video, but I think in general his main point is that the aftermarket stuff is one size fits all and to go with OEM stuff because they're actually designed for the specific car. But if you just want 4 years out of it, quick struts are probably fine. People swear at KYB just like they do Monroe, it's just that Monroe sells a lot more so you think that there aren't that many complaints about KYB but probably the same once you factor in complaints per sale. Yeah, spring is usually when the rebates kick in, Either March or May.
Re: Quick Strut Advice [Re: coopns] #5288727 12/08/19 04:26 PM
slacktide_bitog Offline
Get the KYB quick struts smile
Re: Quick Strut Advice [Re: coopns] #5288785 12/08/19 06:06 PM
B
bullwinkle Online Confused
Online Confused
B
Get the one with the lifetime warranty-I used the Monroes on the front of the MGM about 2 1/2 years ago, and they work as well today as they did then. If they fail, back to AAP for the lifetime warranty they go! They were cheaper with codes from AAP than from RA, and the warranty is easier to deal with-no shipping old ones back if something goes wrong. I'm not sure why Monroe has a bad rap, I don't think I've ever had a replacement shock from them give me a problem.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Quick Strut Advice [Re: coopns] #5288794 12/08/19 06:20 PM
H
Highboy Offline
H
Make sure it’s not your swaybar bushings. I just changed them on my Scion TC and everything is all quiet now. Cheap and easy to try before you go to replace your struts.
2006 Scion tC ST/Oem filter
2008 Scion tC ST/Oem filter
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
[color:red]2019 Subaru WRX[color/]
Re: Quick Strut Advice [Re: Wolf359] #5288824 12/08/19 06:54 PM
Saabist Offline
That is no doubt the case. I tend to keep cars a very long time - the "next owner" being the scrapyard. So I generally look for longer-lived parts when possible.
Re: Quick Strut Advice [Re: coopns] #5288895 12/08/19 08:22 PM
spasm3 Offline
I'm just not a fan of quick struts, unless you are selling the car. Springs may be a different height/rate etc.
Your mechanic recommends them as they are faster for him to change, but not necessarily better.
Oem mounts with Kyb or the monroe spectrum shock.
I have kyb on the elantra and while i'm ok with them, they ride stiffer that stock, harsher to some.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Quick Strut Advice [Re: coopns] #5288941 12/08/19 09:52 PM
J
JeffKeryk Offline
J
I have always found KGB to be a lotta shock for a fair price.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Quick Strut Advice [Re: spasm3] #5288944 12/08/19 09:55 PM
W
Wolf359 Offline
W
Well they are cheaper too. Can't get quick struts for my Mercedes, seems like there's 3 different types of springs so each side is over $400 once you factor in the spring, strut and mount which you have to buy separately and then of course you need the spring compressor too so it's not as easy a job as a quick strut.
