Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
P38 Lightning
by Kamele0N - 01/16/20 03:01 PM
Why does oil in the spark plug hole cause misfires?
by berniedd - 01/16/20 02:27 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
73 registered members (AndyB, 2015_PSD, adams355, alchargo, alarmguy, 4WD, 5 invisible), 1,427 guests, and 16 spiders.
Topics300,215
Posts5,171,076
Members70,452
Most Online3,728
Jan 11th, 2020
Intake vs Head gasket question. #5288505 12/08/19 12:40 PM
007 Offline OP
After a lot of going back and forth with my carb which dumps fuel and my tranny with a stuck modulator I have come to the conclusion that I may be leaking coolant internally as my radiator level has dropped, still have white smoke and water droplets from the tailpipe. Plugs still look fine and I still have no water in the oil or oil in my water/coolant. Is there an easy way of telling which gasket(s) I may have blown? The motor, a 1970 396 was rebuilt not long ago and everything looks normal. I was going to drop in some of those AC/Delco coolant tabs as recommended by someone in my car club but I am not looking to band aid a serious problem even though I am not looking at the cost of having to possible do the head gasket(s). Smoke is the same out of both exhaust tips! Thanks in advance for opinions and/or ideas.
Re: Intake vs Head gasket question. [Re: 007] #5288510 12/08/19 12:52 PM
B
bullwinkle Offline
B
Have you tried a cooling system pressure tester yet? Might be able to see where it is going, the fact both tailpipes looks the same isn't helping-either one smell like antifreeze when it's running?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Intake vs Head gasket question. [Re: 007] #5288518 12/08/19 01:02 PM
Chris142 Online Content
Online Content
If you fill the radiator all the way up when it's cold the coolant will expand and push some coolant out of the overflow. If you look on the side of the radiator there is a stamping on the tank that says "full cold".
Could this be what's happening? Also get a pressure tester and pump the cooling system up when it's cold and look for a leak.
The BB Chevy is a tough engine. While a blown head gasket or cracked head is a possibility it's veryvery rare.
The vacuum modulator is a 3 minute repair. If it's bad it will be a big vacuum leak and that could make the carb dump fuel.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Intake vs Head gasket question. [Re: 007] #5288554 12/08/19 01:33 PM
spasm3 Online Happy
Online Happy
Before delving too far, i'd get a uoa after say 2000 miles on the oil. If you see potassium in the uoa then worry.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Intake vs Head gasket question. [Re: 007] #5288618 12/08/19 02:28 PM
Dave9 Offline
Do a cylinder compression or leak down test. Compare the #'s, and look for bubbling in your radiator.
If any of that looks off, you need to pull the heads. If not, get the manifold gasket, take it apart that far and look for signs of leakage. If nothing is found, do the head gasket too.
You wrote that the plugs look fine, but does the residue on all of them look the same which is more likely intake issue or one (or more) look different like a head gasket?
Re: Intake vs Head gasket question. [Re: 007] #5288743 12/08/19 04:52 PM
A
andyd Offline
A
Check tranny fluid too . If the cooling loop in the radiator is split coolant may be getting into ATF
Thick oil is better grin2
Re: Intake vs Head gasket question. [Re: 007] #5288758 12/08/19 05:21 PM
B
bunnspecial Offline
B
The great think with old engines is that you can do a lot of old diagnostics to narrow down things. These have been mentioned, but just to summarize:
1. Do a compression test and look for less than 10% variation between cylinders. If you have a low cylinder, you have a leak somewhere
2. A leak-down test, either on only the low cylinder or on all of them, can help you pinpoint the leak. As said, bubbling through the cooling system during a leakdown is somewhat definitive for a breached head gasket
3. Look for signs of oil and coolant mixing, including greenish or milky foam on the rockers. You can also check the cooling system for exhaust gases.
4. A cooling system pressure test can be a bit redundant with the above, but can give you additional information
5. One of my favorites-use a boroscope to look in each cylinder. Whether the engine has 10 miles or 100,000 miles on it, you should see some soot and other residue/evidence of it having been run. If one cylinder looks sparkling clean, you probably have a head gasket leaking coolant into the cylinder. Essentially what's happening in this case is that coolant dripping into the cylinder flashes to steam and more or less "steam cleans" the cylinder.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Intake vs Head gasket question. [Re: bunnspecial] #5288786 12/08/19 06:07 PM
M
mattd Offline
M
You should see coolant in the oil with an intake gasket failure. It would be much more likely for a head gasket to cause white smoke/coolant loss than an intake gasket. It would have to have failed on both the coolant port and intake port right next to each other for it to suck coolant through intake gasket, which would be near impossible. You’d certainly have coolant in the oil, too, with that type of failure.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Intake vs Head gasket question. [Re: 007] #5288795 12/08/19 06:22 PM
PimTac Offline
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Intake vs Head gasket question. [Re: 007] #5288796 12/08/19 06:24 PM
Dave9 Offline
?? My last intake gasket failure, I had no coolant in the oil but did have white smoke and coolant loss (and hydrolock).
It was not necessary to have it fail on ports right next to each other, coolant can leak into the valley under the manifold and get sucked into any nearby or all cylinders as each opens and sucks more air in. However in my case, it was a coolant passage going up through the throttle body, so there's that, it didn't have a carb.
Re: Intake vs Head gasket question. [Re: 007] #5288816 12/08/19 06:52 PM
L
Linctex Online Content
Online Content
L
The spark plugs will tell you which cylinder is "burning water" (making steam)
My "guess" is intake gasket.
Re: Intake vs Head gasket question. [Re: Dave9] #5288879 12/08/19 08:02 PM
M
mattd Offline
M
In your case, sure, if you had coolant dumping down the throttle bore then you can hydro lock the engine. However if antifreeze is leaking into the valley of a traditional “V” engine, it’s leaking onto the lifter valley. So yes, you would have coolant in the oil. I can’t make any sense of the second section of your post regarding the intake gasket leak, sorry.
ASE Master, L1
