It's not a bad report per se. Keep in mind that it's 7500 miles so the wear metals will be slightly higher than you might normally see on a UOA. If the other wear metals were higher than avg than I'd be more worried about the copper and since coppers a soft metal it's not as damaging as having chunks of Fe floating around.
I think BS is right, watch for trends in your other metals. If they start to go up you've got a problem developing. Be curious to see a UOA after an equally long run on a Xw30.🤔
