Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
94 registered members (A310, aquariuscsm, atikovi, angeloc, Alex_V, beast3300, 11 invisible), 2,255 guests, and 36 spiders.
Topics300,341
Posts5,173,722
Members70,486
Most Online3,825
Jan 19th, 2020
Liqui moly viscoplus #5288149 12/07/19 10:14 PM
T
Toh1 Online Content OP
OP Online Content
T
I have Honda Pilot 3.5l ivetec 2007 with 300k miles on then now I need to see if I can used visco plus 20206 in them to resided viscosity because engine is little load and burn 1.5 qts of oil for 6000 miles oil change and the viscosity is 2400mpa what is on cst viscoty here is a link for https://products.liqui-moly.us/viscoplus-for-oil-2.html product
Re: Liqui moly viscoplus [Re: Toh1] #5288179 12/07/19 11:28 PM
Marco620 Offline
I would try liquimoly motor oil saver instead. Part number LM 2020
15' Civic 1.8 i-vtec 302,000 mi M1 AP 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,Heckler & Koch & SONY Aficionado
Re: Liqui moly viscoplus [Re: Toh1] #5288184 12/07/19 11:55 PM
M
Mad_Hatter Offline
M
I'm having trouble understanding what you're saying/asking but I think you wanna know if you can use a VM?? Have you tried using a thicker oil (what are you using now) or a HiMi or attempting to address the cause of your oil burning (rings/valve seals) because a VM is just an expensive bandaid while the underlying cause of your oil burning continues worsen..but like I always say, your money - your car.😉
Re: Liqui moly viscoplus [Re: Toh1] #5288247 12/08/19 04:24 AM
demarpaint Offline
300K mile engine using 1.5 quarts of oil in 6K miles? That is not bad at all. I wouldn't mess with it. Bump a grade, try a HM oil would be the only things I'd try, if I tried anything at all.
God Bless Our Troops
Re: Liqui moly viscoplus [Re: demarpaint] #5288256 12/08/19 04:53 AM
M
Mad_Hatter Offline
M
Right!.. there are guys on this board with cars that have half that mileage burning twice as much. I wouldn't waste the $$ on a VM. Maybe a flush and a thicker HiMi lube (10/30 or better) is about all I'd put into an engine that has seen better years.
Re: Liqui moly viscoplus [Re: demarpaint] #5288311 12/08/19 07:37 AM
T
Triple_Se7en Online Content
Online Content
T
Amen to that.
I wouldn't do anything - but be thankful it only uses 1.5qts in 6K.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Liqui moly viscoplus [Re: Toh1] #5288343 12/08/19 08:28 AM
K
Kira Offline
K
One CUP of oil in 1,000 miles.....and somebody has something to say about it other than "HURAH"?
I gotta read this thread completely.
Also, buying a can of something equals viscosity modification? Without lab expertise I thought that was "playing around".
I say this with complete respect.
Re: Liqui moly viscoplus [Re: Toh1] #5288808 12/08/19 06:47 PM
J
John_Conrad Offline
J
can you rephrase this?
Safety doesn't happen by accident.--author unknown
Re: Liqui moly viscoplus [Re: demarpaint] #5288885 12/08/19 08:09 PM
MolaKule Offline
Global Moderator
Global Moderator
My suggestion as well is to Bump the oil viscosity grade to a 5W20 or better yet to a 5W30 HM.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Liqui moly viscoplus [Re: Mad_Hatter] #5288955 12/08/19 10:08 PM
T
OP Online Content
T
Thank you all the reply but I have few jugs 0w20 pennnzoil platinum high mileage oil and I will keep doing that maybe add liqui moly motor oil saver since by car leak oil then it burn 1.5 qts thank you
Re: Liqui moly viscoplus [Re: John_Conrad] #5289198 12/09/19 08:59 AM
T
OP Online Content
T
I want to try liqui moly viscoplus in my car to raise visocity from 0w20 or 5w20 to little higer
Re: Liqui moly viscoplus [Re: Toh1] #5289209 12/09/19 09:12 AM
K
kschachn Online Content
Online Content
K
Again, why not just use a higher viscosity oil to start with?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Liqui moly viscoplus [Re: kschachn] #5289220 12/09/19 09:25 AM
T
OP Online Content
T
I have around 10 jugs of 0w20 or 5w20 in high mileage full synthetic w
Re: Liqui moly viscoplus [Re: Toh1] #5289229 12/09/19 09:35 AM
K
Online Content
K
In that case I'd just mix it with a higher viscosity oil from the same manufacturer. But if you wish to seek out the additive then go for it.
1994 BMW 530i, 251K
Re: Liqui moly viscoplus [Re: Toh1] #5289291 12/09/19 10:37 AM
T
Online Content
T
Give nine friends each a jug for Christmas. Wrap the handles with red bows.
The 10th jug could be dropped off at any VFW Hall for donation purposes.
