Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
87 registered members (aquariuscsm, 53' Stude, adams355, askani79705, aircooled, 18LateModelFan, 10 invisible), 1,932 guests, and 44 spiders.
Topics300,339
Posts5,173,658
Members70,486
Most Online3,825
Jan 19th, 2020
New axle fixed steering pull? #5288137 12/07/19 09:52 PM
Chris142 Offline OP
Our Toyota has had a left pull ever since we bought it last year. I have rotated the tires,checked air pressure etc. No change. I was going to have the alignment checked soon.
It has had a leaking CV boot for a few weeks or so. A family emergency came up so I had to put an axle in it to be safe on a trip that suddenly came up.
No more left pull! The parts I removed had zero effect on the alignment. it uses eccentrics on the lower control arm mounts. I didn't touch those,I took the knuckle off at the ball joints.
How could an axle cause a pull?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: New axle fixed steering pull? [Re: Chris142] #5288139 12/07/19 09:58 PM
E
eljefino Offline
E
What if simply jacking it up did something to a bushing that tweaked your alignment for the better, like popping a shoulder back in?
Re: New axle fixed steering pull? [Re: eljefino] #5288142 12/07/19 10:04 PM
AZjeff Offline
Possible, maybe, but if so means more repairs are needed. You'd think a mechanic like the OP would notice something that worn.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: New axle fixed steering pull? [Re: eljefino] #5288144 12/07/19 10:07 PM
Chris142 Offline OP
Everything looks good. No weird clunks or rubber spitting out. I had the same parts off a few months ago when I put struts in it.
I'm thinking that the axle had some sort of binding.
Re: New axle fixed steering pull? [Re: Chris142] #5288168 12/07/19 10:55 PM
53' Stude Online Content
Online Content
Hmmm, wonder why this was not fixed shortly after vehicle was purchased? popcorn
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: New axle fixed steering pull? [Re: 53' Stude] #5288182 12/07/19 11:41 PM
Chris142 Offline OP
Time,finances.life in general
Re: New axle fixed steering pull? [Re: Chris142] #5288269 12/08/19 05:48 AM
Char Baby Online Content
Online Content
Although it's only happened to me once, I had just the opposite happen when installing a axle. I got a pull on the same side as the installed axle.
It wasn't a bad pull(just noticeable) so I left it alone and had a new alignment done when I performed other repairs that actually required the alignment.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: New axle fixed steering pull? [Re: Chris142] #5288325 12/08/19 07:56 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If it had a leak, I’d assume it was low on lube. If that’s the case, binding or just slightly higher friction could be the case.
How that results in a pull is not entirely clear, but I guess it’s possible..
Re: New axle fixed steering pull? [Re: Chris142] #5288441 12/08/19 10:54 AM
B
bullwinkle Offline
B
Too late to check now, but if the old one was getting hot, that would be a symptom of it binding, much like a sticking caliper.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: New axle fixed steering pull? [Re: Chris142] #5288446 12/08/19 10:59 AM
M
mightymousetech Offline
M
Yes, can definitely be the cause. Would be similar to a dragging brake caliper.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, BMW 0W30, MT-LV
Re: New axle fixed steering pull? [Re: mightymousetech] #5288459 12/08/19 11:10 AM
M
mattd Offline
M
Was the axle that was bad on the left side or the right?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: New axle fixed steering pull? [Re: Chris142] #5288493 12/08/19 12:09 PM
A
andyd Offline
A
One of the ball joints got seated properly when it was re-tightened . A pull that doesn't cause tire wear isn't much of a problem.Glad you fixed it, Chris grin2
Thick oil is better grin2
Re: New axle fixed steering pull? [Re: mattd] #5289016 12/09/19 12:34 AM
Chris142 Offline OP
Driver side. Just the boot was beginning to split.
Re: New axle fixed steering pull? [Re: Chris142] #5289495 12/09/19 03:13 PM
DGXR Offline
I agree, any additional friction or inefficiency between the shafts would result in a steering pull. Maybe additional wear due to leaked lubricant caused more friction? Which way was the steering pull relative to the new shaft?
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
