Miles on Civic - 568,494 / 914,902 km
Miles on oil - 6,452
Amsoil AZO 0W-30 oil
Amsoil Ea15k20 oil filter
2 Filtermag CT3.2 magnetic oil filters
Dimple magnetic oil drain plug
5 ozs Liquimoly
37 ozs make up oil
Blackstone Labs; This engine is still going strong at an impressive 568,494 miles. The wear levels are stable, which is great, and the lack of potassium and sodium tell us your
coolant fix was good and that the last drops of coolant have all but washed out. You did get a little more fuel in the oil this time, but 1.8% is still within the
"could be from normal operational considerations" range, so no worries there. The TBN was good at 3.8, and the ISO Cleanliness Code was fine at 15/14/11. When
you hit 600K, you'll have to come up and celebrate over beers with us. Great work!
Aluminum----------4--------------------------------------4(universal average based on a 5,900 mile OCI)
Chromium----------1--------------------------------------1
Iron-------------------16------------------------------------9
Copper---------------2--------------------------------------3
Lead------------------0---------------------------------------2
Tin---------------------0---------------------------------------1
Molybdenum--------284------------------------------------88
Nickel-----------------0----------------------------------------0
Manganese---------0----------------------------------------0
Silver------------------0---------------------------------------0
Titanium--------------0---------------------------------------1
Potassium-----------6----------------------------------------4
Boron-----------------68--------------------------------------51
Silicon-----------------9---------------------------------------11
Sodium----------------10-------------------------------------42
Calcium----------------1255---------------------------------2120
Magnesium------------968-----------------------------------163
Phosphorus------------737-----------------------------------713
Zinc-----------------------821-----------------------------------833
Barium--------------------0--------------------------------------0
SUS Viscosity @ 210 F--------------59.9-----------------57-67(values should be)
cSt Viscosity @ 100 C----------------10.19---------------9.4-12.4
Flashpoint in F---------------------------340----------------->375
Fuel in %-----------------------------------1.8----------------- Antifreeze %------------------------------0--------------------0
Water %-------------------------------------0--------------------0
Insolubles %-------------------------------0.3----------------- TBN------------------------------------------3.8------------------>1.0
Tan-------------------------------------------not done
Particle counts for ISO Code 15/14/11;
>=2 microns-------436 particles
>=5-------------------161
>=10------------------45
>=15------------------17
>=25-------------------4
>=50-------------------0
>=100-----------------0
