I read a while ago about using a garden sprayer to pump your fluids I think it's a great idea. I typically do a cold drain and fill on sealed trans units, so I always measure it. My question is; the black tube in the sprayer(pump), does it retain any Fluid or does it all get pumped out? I only ask as I don't want to underfill.or is there no fluid inside there at all? Obviously I don't fully understand how they work ...
I was hoping someone here has used this method and has some insight. The garden sprayer is enticing option because pumping by hand gets old!
