Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
dfrybeck, ckinch1, EAC1, Kronguy, jamespeter26
70492 Registered Users
97 registered members (aircooled, 2K2AcuraTL, 2004tdigls, AndyB, 90crvtec, Alfred_B, 11 invisible), 1,880 guests, and 16 spiders.
Topics300,379
Posts5,174,632
Members70,492
Page 1 of 4 1 2 3 4
Engine sounds and drives way better after oil change #5287363 12/07/19 12:42 AM
A
apollo18 Offline OP
A
I know this has probably been beat to death but I’m confused about something. So I was running castrol edge 5w30 or another name brand full synthetic and I decided to get an oil change a couple thousand before the actual due date as winter is approaching. The oil still had life left and my truck olm never said anything. I got a fresh oil change with the Dexos 2 gm stuff at the dealership and wow the truck sounds and drives way smoother and better now. It just feels completely different at the same oul weight. What I don’t understand tho is that the old oil that was in the vehicle before was full synthetic name brand and still had tons of life left but now with fresh oil my truck sounds and drives way better?
Anyone can explain this? Cuz I know for sure the old oil in the truck wasn’t bad and easily could have been run longer so the answer can’t be “the old oil needed to be changed”
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287365 12/07/19 12:58 AM
O
OilUzer Offline
O
The new oil is probably thinner and maybe more moly and your engine likes the thinner oil.
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287369 12/07/19 01:21 AM
dogememe Offline
Dexos1Gen2 or Dexos2?
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Engine sounds and drives way better after oil change [Re: OilUzer] #5287384 12/07/19 02:37 AM
Z
ZeeOSix Offline
Z
Or maybe the new oil is thicker (old oil was sheared and diluted) and that engine likes thicker oil.
Re: Engine sounds and drives way better after oil change [Re: ZeeOSix] #5287388 12/07/19 02:48 AM
4WD Offline
My Ecoboost was quieter on M1 0w40 than with M1 or PUP 5w30
My 5.3L is quieter than the eB and that’s on 0w20.
Re: Engine sounds and drives way better after oil change [Re: ZeeOSix] #5287393 12/07/19 03:21 AM
O
OilUzer Offline
O
-1-
iirc, fuel economy/efficiency is one of the considerations with dexos oils and maybe more moly or the equivalent as well ...
-2-
also op went from Castrol Edge (I assume non-dexos based on his post) to a dexos oil ...
Based on the above, the odds are that the op went from thicker to thinner.
there is also imagination factor but let's not go there! My car sounds and runs better when I top up fluids and wash the car. grin2
Re: Engine sounds and drives way better after oil change [Re: OilUzer] #5287397 12/07/19 03:48 AM
M
Matt1980 Offline
M
That was my thought, My 2011 GMC Terrain I4 sounds noticeable quieter and feels smoother with PP. PP 5w-30 is known for being on the thin side of the 5w-30 spectrum. Could just be my imagination but other people over at the terrain forums mentioned the same thing.
Re: Engine sounds and drives way better after oil change [Re: ZeeOSix] #5287399 12/07/19 03:51 AM
demarpaint Offline
That could very well be the case too.
God Bless Our Troops
Re: Engine sounds and drives way better after oil change [Re: 4WD] #5287408 12/07/19 04:30 AM
B
bbhero Offline
B
You getting your hearing aides in your stocking this year 4wd ?? LOL
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287439 12/07/19 06:25 AM
K
ka9mnx Offline
K
I've had the same experience as the OP and the oils were, basically, the same "thickness" with an HTHS of 3.1/3.2.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287448 12/07/19 06:39 AM
sloinker Offline
Maybe they checked your rig for any missing computer flash TSB's and flew them in while they had your vehicle.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287453 12/07/19 06:47 AM
T
Trav Offline
T
I bet if you let the wife drive it she wouldn't notice anything. That is when you know it was all in your head which is probably the case.
What happened is you went in with hot thin oil in the pan and they filled it with cold oil which is thicker until it warms up, that's all it is.
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287454 12/07/19 06:48 AM
T
Triple_Se7en Offline
T
Are you sure / positive you had Castrol Edge prior? I ask because you didn't name-brand, what's currently inside your engine.
Unless you do these changes yourself, you are liable to get something different than expected. So much dishonesty out there these days. Even the receipts handed the customer are sometimes wrong. You may receive synblend instead of synthetic and you may receive a viscosity that's different than ordered by you.
Cat & Mouse and Catch Me If You Can is wrapped completely around some of these oil change places..... Dealerships Included!
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287472 12/07/19 07:23 AM
T
TiGeo Offline
T
placebo
2018 VW Atlas SEL 4Motion 3.6 VR6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 TSI Unitronic St2 IS20 - LiquiMoly 5W40 VW filter
2013 Ford Focus SE HB 2.0 Ti-VCT - MC syn-blend 5W20 MC filter
Re: Engine sounds and drives way better after oil change [Re: apollo18] #5287473 12/07/19 07:25 AM
J
joekingcorvette Offline
J
I would say the old oil was dirty and the new oil lubricated the engine better which made it quieter. I have experienced this myself. My son has a Honda Civic just like mine with about the same miles and his engine is noisier. I think more than likely it's because he doesn't change his oil as frequently a I do. I have noticed this in other vehicles. Keep the oil clean and the engine most likely will run a little quieter. If not, you wasted a few bucks no big deal for peace of mind.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Page 1 of 4 1 2 3 4
