Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
dfrybeck, ckinch1, EAC1, Kronguy, jamespeter26
70492 Registered Users
91 registered members (AandPDan, 2K2AcuraTL, 90crvtec, AlienBug, aircooled, Antiquity, 10 invisible), 2,128 guests, and 16 spiders.
Topics300,380
Posts5,174,644
Members70,492
2012 GMC Terrain 3.0L V6 Valve Cover Replacement #5287194 12/06/19 07:30 PM
B
benjamming Offline OP
B
2012 Terrain 3.0L V6 flex fuel engine with 207k miles
Oil was in one of the spark plug tubes (middle front cylinder - didn't look up the #). Not much oil but noticeable. Next step it would naturally seem (intake manifold already off) is to replace the valve cover gaskets & spark plug tube seals. What is the valve cover bolt torque spec?
Also, I found the below when reading up some on this problem. Anyone have the bulletin where this was issued? My first step is to rule out the valve cover gasket & spark plug tube seals, but this is looming. Vehicle sets a general misfire code every week or so but no driveability issues yet.
Fluid in Spark Plug Tubes
March 25, 2013
A Check Engine light may be illuminated with misfire DTCs set, or a possible oil or coolant leak may be found, on some 2010-2013 Enclave, LaCrosse, CTS, SRX, Camaro, Equinox, Traverse, Acadia, Terrain; 2012-2013 Caprice PPV, Captiva, Impala; 2013 ATS and XTS models equipped with 3.0L and 3.6L (RPOs LF1, LFW, LLT, LFX) HFV6 engines. (Fig. 10)
On inspection, coolant or oil may be found in a spark plug tube. Determine if the oil or coolant is coming from the spark plug tube and not leaking into it from above. If the spark plug tube is leaking, replace the cylinder head, spark plug and coil.
Porous spots in the head created during manufacturing cause the leak. The spark plug tubes are permanently sealed into the head and are not replaceable.
If a cylinder head is replaced for this condition, mark the faulty spark plug tube before sending the head in for warranty or core so GM Engineering or the re-manufacturing facility can identify it.
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: benjamming] #5287206 12/06/19 07:55 PM
J
JTK Offline
J
Yikes. "Replace the cylinder head" can't be a pleasant job on these.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: benjamming] #5287209 12/06/19 08:00 PM
Chris142 Offline
Junk
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: Chris142] #5287212 12/06/19 08:14 PM
dishdude Offline
Originally Posted by Chris142
Junk
You should really reconsider giving such helpful advice away for free.
It's normal for the bottom part of the tube to be part of the head, but the top that seals with the VC should be replaceable. At 207k, it's pretty safe to say you don't have a porous head.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: benjamming] #5287232 12/06/19 08:39 PM
double vanos Offline
I say put it back together and keep on motoring.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: benjamming] #5287240 12/06/19 08:45 PM
B
B
Yep, plan on keeping it going, but would like the valve cover torque value to minimize leakage issues later.
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: benjamming] #5287265 12/06/19 09:17 PM
super20dan Offline
I agree these cars are junk. everything gm makes is junk except the fullsized trucks
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: super20dan] #5287298 12/06/19 10:08 PM
B
BTLew81 Offline
B
Value added post....filled with fact.
duh
2018 Honda Accord Sport 2.0T/10 Speed
Modern Steel Metallic/Black
Factory Fill/Filter
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: Chris142] #5287311 12/06/19 10:31 PM
dogememe Offline
Junk
It has 200k miles. A leaky valve cover gasket at that mileage isn't junk, it's normal.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: BTLew81] #5287314 12/06/19 10:38 PM
4WD Offline
Yeah … impressive
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: Chris142] #5287344 12/06/19 11:17 PM
G
gregk24 Offline
G
Junk
Wow, that was helpful. 207K miles seems like a good run to me.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: gregk24] #5287425 12/07/19 05:45 AM
demarpaint Offline
Junk
Seems like a good run to me too.
God Bless Our Troops
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: benjamming] #5287460 12/07/19 07:02 AM
M
MrHorspwer Offline
M
March 25, 2013
This isn't from a TSB. This is from what GM calls a PI, or Preliminary Information.
By law, TSBs are required to be published as public knowledge. Anyone can access them for free. A PI is like an internal TSB. A PI can only be viewed by associates within the manufacturer's service organization. They are not freely published. All manufacturers have a similar system, not just GM.
Often, a PI may precede a TSB when the manufacturer is looking for more information on a specific issue or trying to scope a concern. Sometimes they'll even have the phone number of an engineer to call if you have a vehicle with the described condition. Like I said, they're intended for professionals within the manufacturer's service organization.
In other cases, as PI is written to provided specific instructions as it relates to servicing within the manufacturer's service administration. I think this is the case here. Looking at the PI, it's actually applicable for every single vehicle equipped with a 3.0L or 3.6L V6 from 2010 to 2019. This are different engine RPOs manufactured in different locations, using different castings, etc. There is nothing common about the engines involved. That's because the PI isn't necessarily about the oil/coolant leak issue, it's about what the manufacturer wants the technician to do when they find the issue:
Quote
That integrated spark plug tube may be in an awkward location that magnaflux testing doesn't show very well during the re-manufacturing and visible identification may be difficult after cleaning. They're asking techs to mark it so the re-manufacturer knows to specifically looks there. Again, not something the general public needs to know, but if you're in the business of selling warranty cores to re-manufacturers, that's a different story.
Re: 2012 GMC Terrain 3.0L V6 Valve Cover Replacement [Re: dishdude] #5287468 12/07/19 07:18 AM
B
bullwinkle Offline
B
Junk
I have to agree with try a gasket & keep going, at 207K it's ahead of the curve. Better than Ford! (& no, I'm not going into detail for the millionth time!) crazy
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
