Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
67 registered members (aircooled, Aero540T, askani79705, aquariuscsm, Astro14, 9 invisible), 1,787 guests, and 39 spiders.
Topics300,339
Posts5,173,628
Members70,486
Most Online3,825
Jan 19th, 2020
Base oil different in 0W vs 5W? #5286893 12/06/19 12:54 PM
doyall Offline OP
Just how much difference can there be in the base oil of a 0W vs a 5W in a same brand/same specs oil. Take the latest versions of Pennzoil Platinum 0W-20 and Pennzoil Platinum 5W-20 for instance. Other than pour point depressants or some other additive in one or the other, what could the differentiation be?
Re: Base oil different in 0W vs 5W? [Re: doyall] #5286912 12/06/19 01:17 PM
P
PandaBear Offline
P
Assuming you are talking about synthetic, the 0w vs 5w would likely be a different blend of low and high visc synthetic base. This usually means the 0w one will have more low and high visc while the 5w will be more in the middle. When this happen the long term result is the lower visc base will evaporate / burn off in long drain, so the oil has a higher volatility.
The higher end long drain oil like Mobil1 EP will likely use PAO for the lower visc base to reduce that.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Base oil different in 0W vs 5W? [Re: doyall] #5286916 12/06/19 01:18 PM
SubieRubyRoo Offline
Unless it's changed very recently, 0W20 is always going to be a synthetic base. 5W20 can be full, blend, or conventional. So, there can be huge differences.
However, it's always a point of contention here on the board if: 1. the base oil is more important, or 2. data shows that the higher the spread between the W rating and the oil weight makes the oil less stable, but 3. 0W40s should be terrible, yet they meet and hold some of the highest certifications available.
So... long story short, if both the 0W and 5W versions meet your engine's requirements, you will be able to discern no difference in operation.
Re: Base oil different in 0W vs 5W? [Re: doyall] #5286918 12/06/19 01:20 PM
A
aquariuscsm Online Content
Online Content
A
I’ve seen a few 0W20 synthetic blends. Pennzoil Gold being one of them.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Base oil different in 0W vs 5W? [Re: doyall] #5287154 12/06/19 06:22 PM
B
benjy Offline
B
a look at noacks on better real synthetics aka redline shows the overall thinner oils to have more burn off, so unless in extreme cold the slightly thicker 10-30's are a better choice as everyone is stretching their oil changes to save a little $$$ while possibly compromising protection. with many trading often any issues will be found by the next owner looking to see 200 thou
Re: Base oil different in 0W vs 5W? [Re: SubieRubyRoo] #5287210 12/06/19 08:00 PM
K
Kamele0N Offline
K
Originally Posted by SubieRubyRoo
So... long story short, .
.....you are GTGO with 10w40 smile Shell rimula with GTL or Shell helix with XHVI....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Base oil different in 0W vs 5W? [Re: SubieRubyRoo] #5287262 12/06/19 09:15 PM
Doublehaul Offline
Agree 99% only thing I’d say any different as that while some 5-20s are called conventional...I honestly don’t think we have any tru conventional oils any more. Many of the “conventional” oils have proven to blends in their pds etc and have for a long time...dare I say since SN came into play perhaps even SM.
Agree also that 0w40s shoot holes in the w to viscosity spreads being less stable
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Base oil different in 0W vs 5W? [Re: benjy] #5288279 12/08/19 06:35 AM
ChrisD46 Offline
*Would a 10W30 offer less start up protection than a 5W30 ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Base oil different in 0W vs 5W? [Re: ChrisD46] #5288388 12/08/19 09:19 AM
A
Online Content
A
My thought on that has always been, would a 10W30 leave a better residual film on the upper end vs a 0W draining down? I may be completely wrong.
Re: Base oil different in 0W vs 5W? [Re: doyall] #5288633 12/08/19 02:39 PM
SR5 Offline
For the heavier grades, sometimes 5W40 would be a Group III synthetic, while 0W40 would be a PAO Group IV synthetic.
I believe that is why Edge 5W40 is MB 229.3, while Edge 0W40 is MB 229.5 as it meets the lower Noack volatility requirements of the higher spec (10%) by using PAO.
Of course you could make a PAO based 5W40 that is even less volatile again, but that is a rare beast.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
