Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
Harry_Seaward, MrH1325, Thetarmac, lbstyling, tanpw
70483 Registered Users
38 registered members (Bighorn2500, Astro_Guy, Bookmaker, brages, 77GrandPrix, 6 invisible), 1,383 guests, and 22 spiders.
Topics300,336
Posts5,173,605
Members70,483
Most Online3,825
Jan 19th, 2020
Thoughts... Tough Guard vs Extended Guard (9688) #5286846 12/06/19 11:56 AM
wemay Offline OP
The new boxes list these attributes...
TG - 15K mile protection - $9.XX
EG - 10K mile protection - $5.XX (now with silicone ADBV)
TG - 99% efficiency (better media?)
EG - No longer lists efficiency numbers but used to say 95%
Question: is the 4% better efficient worth it to you to spend almost 50% more for the TG?
*full disclosure, i have a few of each in my stash.
2019 VW Passat Wolfsburg TSI
Castrol Edge Professional LL IV FE 0W-20, OEM
2013 Hyundai Santa Fe Sport 2.0T
Mobil1 Annual Protection 5W30, M1-104
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5286850 12/06/19 12:06 PM
V
volk06 Offline
V
To me it would all depend on how long your OCIs are, this is how I break them down when doing maintenance.
3-5K = EG
5-10K = TG
10K+ = FU
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: volk06] #5286880 12/06/19 12:37 PM
L
Lubener Offline
L
3-5K = EG
5-10K = TG
10K+ = FU
That sums it up pretty good.
The "thinking" man's friend.
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5286885 12/06/19 12:49 PM
J
JLTD Offline
J
You only buy 2x TG at $18.xx
for every 3x EG at $15.xx so it's even more of a narrow comparison.
How much is the Ultra for your application?
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: JLTD] #5286913 12/06/19 01:17 PM
wemay Offline OP
The Xtra Guard is $11.XX. but i'm not in need of it even though i have used them in the past because my OCI rarely exceed 4.5K miles. I might consider running the TG for two oci.
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5286914 12/06/19 01:17 PM
circuitsmith Offline
Just going by those numbers:
One filter lets 1% of the dirt through, the other lets 5%.
So it it worth it to you to spend almost 50% more for the TG, which lets 5X less dirt pass through?
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: circuitsmith] #5286977 12/06/19 02:45 PM
CR94 Offline
Originally Posted by circuitsmith
... One filter lets 1% of the dirt through, the other lets 5%. ...
Yes, that's a less misleading way to phrase the numbers in such examples.
Approximate prices at Walmart the last time I checked for my cartridges size:
EG: $6.60
TG: $9 (only 36% more $)
XG: $11.
There's also the $3 SuperTech, which appears identical in construction to EG, but may use different media. It claims 99% efficiency for 30um.
2011 Toyota Prius now at 107K
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5287014 12/06/19 03:37 PM
G
geeman789 Offline
G
I always wondered where exactly the Tough Guard is supposed to fit ...
Is it really better than a regular Extra Guard ? Similar construction, filter media seems SLIGHTLY better, but if you really want a premium filter, for only a couple of dollars more that Ultra is usually sitting right beside it.
However, many years ago I took a marketing course, and it seems that companies know that the average consumer will often step up one level from the bottom tier, so as not to feel cheap. The Tough Guard costs very little extra to build, but sells for a few dollars more. If people buy it, good for Fram.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5287073 12/06/19 04:36 PM
K
krismoriah72 Offline
K
I would probably not use the 9688 and use the 7317 instead.
at my walmart the XG7317 is $9 and good to go for 20K.
Here is one cut open with 20K miles
https://www.bobistheoilguy.com/foru...am-xg7317-20k-miles-cut-open#Post5270352
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5287078 12/06/19 04:42 PM
spasm3 Offline
I run the ultra on everything. Even on the mazda for 3k changes.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5287079 12/06/19 04:42 PM
dlundblad Offline
Does the 3593a interest you? Should be priced like most of the other EG’s.
Same physical size of the 9688.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5287083 12/06/19 04:45 PM
J
JLTD Offline
J
... because my OCI rarely exceed 4.5K miles. I might consider running the TG for two oci.
There it is....OCI <=4500 miles, TG for 2 intervals - well within the rated 10k.
$8.99 instead of $11.98 plus better filtration. Done.
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: dlundblad] #5287124 12/06/19 05:38 PM
wemay Offline OP
The 9688 is the one recommended for the two vehicles in my sig.
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: geeman789] #5287128 12/06/19 05:44 PM
Z
ZeeOSix Offline
Z
The TG is higher efficiency than the EG. The TG is 99% @ 20um and the EG is 95% @ 20um.
The TG and XG are basically the same efficiency (99% vs 99+% ... hair splitting). The difference is the XG is rated for longer use. The XG holds more debris and can therefore take a longer change interval. So the TG fits the high efficiency filter, but for shorter use. Of course, as some do here, the XG can be ran for 2x OCIs which would end up being cheaper than running two TGs.
Re: Thoughts... Tough Guard vs Extended Guard (9688) [Re: wemay] #5287130 12/06/19 05:46 PM
Z
ZeeOSix Offline
Z
Fram shows the EG efficiency to be 95% @ => 20um as before. Click on the "Media" bar on Fram's website.
