Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
121 registered members (69Torino, 2010Civic, 2009Edge, 4WD, 53' Stude, 13 invisible), 2,896 guests, and 22 spiders.
Topics300,646
Posts5,180,131
Members70,541
07 Saturn Ion 2.0 L clutch replacement #5286355 12/05/19 07:23 PM
N
Nitronoise Offline OP
N
My oldest daughter has lost her clutch in her Ion,,, she went to her shop that she trades with and they came back with a 1200 to 1300 estimate
seems high to me as she is in the Milwaukee Metro area ,, my youngest lost her automatic trans in her 02 tarus and we got a complete overhaul , seals clutch packs and torque converter ,for 950.00 and she is in the chicago suburbs not milwaukee
I know its apples to oranges but my price is 395.00 for disk , pressure plate and throw out bearing , and a slave cylinder for the clutch is 70 bucks
I would do it myself but I am in the start of a rehab stint after shoulder surgery and hoisting little 5 speeds will not heal me up very well
kind of looking for everyones thoughts on the pricing
07 Ford Freestyle 166K
06 Honda Acord EX 133K
02 Ford Tarus 123K
00 Buick Regal SC 144K
95 Goldwing 28K
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286367 12/05/19 07:35 PM
J
JayhawkRoy Online Content
Online Content
J
Repairpal says $1247-$1428 for Milwaukee area. Sounds reasonable/ballpark to me.
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286370 12/05/19 07:37 PM
A
atikovi Online Content
Online Content
A
Couldn't you coach her to do the job?
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286394 12/05/19 07:56 PM
F
FirstNissan Offline
F
Sounds about right from what I have heard/dealt with in the past.
PS. you got out cheap on the taurus automatic rebuild. I actually owned a 2005 taurus, rebuild in Louisville 4-5 years ago was quoted at almost $2K! I scrapped the car.
2017 Toyota Sienna
2019 Toyota Camry
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: atikovi] #5286396 12/05/19 07:57 PM
PimTac Offline
What a useless comment.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: PimTac] #5286404 12/05/19 08:06 PM
A
Online Content
A
And that's a sexist comment. I bet you wouldn't say that if it was his sons car.
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286412 12/05/19 08:14 PM
N
nwjones18 Offline
N
Well I'm not sure if it helps much but Clutch kits with the slave cylinder are only around $200 on Rockauto..
https://www.rockauto.com/en/catalog/saturn,2007,ion,2.0l+l4+supercharged,1433712,transmission-manual,clutch+kit,1993
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286414 12/05/19 08:20 PM
T
tiger862 Offline
T
Coach her up. Give her a manual to guide her and with your support she will learn something. I have done this on occasion with my daughter.
Tiger862
2018 Grand Caravan
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286417 12/05/19 08:22 PM
N
N
no I have a commercial account with my local pepboys and the shop will not let me bring in parts ,,,,,,,,,,,,,,,,,,,,,,,,, cry
02 Ford Tarus 123K
95 Goldwing 28K
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: tiger862] #5286419 12/05/19 08:26 PM
N
N
she does her own light maintenance oil and filter , just did plugs and a battery of winter ,,,,,, not equipped for trannys and heavy stuff
02 Ford Tarus 123K
95 Goldwing 28K
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: PimTac] #5286447 12/05/19 09:02 PM
V
vw7674 Offline
V
Use a sling & a 2-ton Come Along from a truss......it's only a sub-100 pound transaxle.
I did that when I was in no mood to bench press an 85 pound 5 speed, only thing I strained was my patience
swapping out a measly $22 throw out bearing that had torn open like a tuna can. : ( Stupid Nissans. YMMV.
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286457 12/05/19 09:11 PM
E
eljefino Offline
E
I think it's a hassle on this car-- engine and transaxle have to come out together then gets split on the ground.
So then you have to finagle an old rusty exhaust off.
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: eljefino] #5286463 12/05/19 09:15 PM
V
vw7674 Offline
V
Now I get the $1200-1400 estimate.
Probably let the garage deal with it.
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286506 12/05/19 10:04 PM
slacktide_bitog Online Content
Online Content
Pep Boys will do it for $500 parts and labor hide
Re: 07 Saturn Ion 2.0 L clutch replacement [Re: Nitronoise] #5286547 12/05/19 11:51 PM
R
rubberchicken Offline
R
READ THIS !!
I have a 2006 Ion Redline 2.0. which is identical to your 2007. I also have an active AllDataDIY for this vehicle. Here are the labor rates from AllData:
The mfg rate for a warranty repair is 4.3 hours, and standard rate is 8.1 hours. OEM Clutch disk is part 12589049 and indicates about $136 . Pressure plate is 12583856 and is $222.
It looks like the transaxle must be R&R to replace the clutch disk, and replacing the pressure plate only adds .2 hours, and pilot bearing another .2 hours. They do not break down the difference on the on the M86 vs MU3 trans- one is LSD and the other is not LSD, so I think it just does not matter for purposes of clutch labor or parts. If you want, PM me for more info. So given that info, I think the estimate you got is right on the money - 8-9 hours labor plus parts. Since this engine and trans was common to the Cobalt SS, you could get another estimate at a Chevy dealer and see how it compares. If the car is otherwise in decent shape, then it would be worth repairing- my car has been quite reliable, 140k miles with original clutch, averages 28 mpg. If it has LSD and/or the Competition Package (grey center wheels, boost gauge above the steering wheel) then that adds about $1,000 to the used price.
Something to note- this car has a very light flywheel, and if you have the Stage II or higher kit it could be over 250 hp to the wheels: mine has head work and other mods so its pushing over 300 hp, and runs ~13.8 in the 1/4 mile. It takes a delicate touch to get the clutch just right, so somebody that is ham-fisted or lazy can easily wreck the clutch in short order.
